UDCnom
Has thanked: 330 times
Been thanked: 848 times
UDCnom
So reading the code and not having used UDCnom yet i was wondering if there is a bit of explaination the coding, reading code just made it more confusing.
   if (udcnom > 0)
      s32fp udcdiff = udcfp - udcnom;
      s32fp factor = FP_FROMINT(1) + FP_DIV(udcdiff, udcnom);
      //increase fweak on voltage above nominal
      fweak = FP_MUL(fweak, factor);
      //decrease boost on voltage below nominal
      boost = FP_DIV(boost, factor);
If I am correct, as soon as UDCnom is set to a value other the zero will values for Fweak and Boost will change based on the factor.
So would the equation for the factor be: (UDC measured - UDCnom) /UDCnom ?
No the comment really throws me off, as I would expect the boost to need to increase to keep the resultant effective voltage the same?
From wiki: boost At full throttle an effective voltage of 1700/37813*355=16V is generated. Thus a lower voltage is a lower effective voltage. :idea:
Re: UDCnom
Hi Tom,
the second comment is indeed wrong. So say udcnom=500, fweak=100, boost=2000 and measured udc (udcfp) is 480. Then udcdiff=-20 and factor is 1+(-20/500)=0.96. Then fweak is lowered to 100*0.96=96 and boost INCREASED to 2000/0.96=2083. Code correct, comment wrong.
Thats why "Clean Code" advises against comments: they add redundancy. I happily adhere to their advise, usually :P
Re: UDCnom
No wonder having different packs make certain tunes feel vastly different.
Will start using UDCnom now as standard.
Re: UDCnom
Yes I certainly recommend it. Especially on non-LFP packs whos voltage changes a lot over the discharge cycle.
jon volk
Re: UDCnom
Post by jon volk »
Great info! I definitely need to update my setting in this case.
Re: UDCnom
I would be careful, as depending on at what battery voltage you sought out most limits this will determine your true UDC nom.
So i would lean more to the cautious side, however on large drive units from experience you need to drop alot of voltage (having ran with 280V systems using a 360ishV proven tune) to notice a big impact on performance down low.
jon volk
Re: UDCnom
Post by jon volk »
I’ve been thinking about this value a bit. If fweak determines the speed at which maximum power is generated, wouldn’t it be more consistent to keep this value the same and scale fslipmax with pack voltage?
Re: UDCnom
Thats what happens if you use udcnom AND also use fconst and fslipconstmax. Those two will start increasing the slip above fweakcalc until it peaks at fconst.
jon volk
Re: UDCnom
Post by jon volk »
Great. I’m going to have to look at the calculations to understand it.
jon volk
Re: UDCnom
Post by jon volk »
So based on your example configuration, I put the numbers in a spreadsheet in an attempt to better quantify the changes. Care to take a quick look at the logic here and see if it's accurately representing what's happening between udc/udcnom/fslip/fconst/etc?
Boost-Slip calcs.xlsx
(10.88 KiB) Downloaded 156 times
dima
Re: UDCnom
Post by dima »
I believe your excel formula is a bit wrong E14 should be
=1+(E13/E11)
jon volk
Re: UDCnom
Post by jon volk »
Indeed, good catch.
Updated the file in case anyone else may find it useful for setting things up or if anyone else catches an error.
(10.94 KiB) Downloaded 126 times
dima
Re: UDCnom
Post by dima »
Is it possible to put something similar for ampnom?
