The ZombieVerter VCU Project
Locked
Alibro
Has thanked: 506 times
Been thanked: 324 times
Post by Alibro »
Koppi wrote: Wed Oct 06, 2021 8:23 am Hello conversion friends,
I am Peter from Germany and a beginner in converting vehicles !
I will install a Leaf Gen1 in a Mercedes W123.
Both cars I already have and the Leaf components I have already removed
I have already ordered the ZombieVerter
I have a request to the specialists
Which of the Leaf components can I continue to use ?
Motor and controller is clear !
BMS ?
Charger ?
DC/DC ?
I have seen in the video that Damien has made the Gen2 run completely
Does this also work with the Gen1 ?
Thanks for your help !
Peter
If you are using the Leaf battery then it is possible to make Charger and DC-DC work with or without the ZombieVerter. Watch all the videos posted here for more info. https://www.youtube.com/user/horndoggie999
If not using the Leaf battery then you are in the same position as me and waiting for the ZombieVerter to be configured for the Gen1 VCU so that charging is possible. In this case BMS is a different issue completely and not relevant to this topic.
Koppi
Post by Koppi »
Thank you for your professional answer !
If I connect the BMS and the charger with CAN, the system will work without the VCU?
as in this diagram :
https://activeautomation.co.nz/images/t ... mages.jpeg
I have another question:
I wanted to try powering the charger with 12V to read the CAN-BUS.
I have connected 12 volts to pin 11/12/13 and GND to pin 22.
CAN on Pin 19/20
unfortunately I don't get any CAN data
CAN_500KBPS is correct ?
greetings
Peter
Alibro
Post by Alibro »
Koppi wrote: Wed Oct 06, 2021 5:25 pm Thank you for your professional answer !
CAN on Pin 19/20
greetings
Peter
Sorry I don't know the answers you are looking but you should start a new thread about these questions as they are not relevant to the ZombiVerter.
Been thanked: 1133 times
I have answered this before but one more for the road :
Gen1 : inverter and motor only.
Gen2 : full stack. Inverter,motor,pdm.
Gen3 : full stack testing in progress.Not yet released.
Zombieverter does not implement any BMS comms rather uses the ISA shunt for battery monitoring. BMS comms is left to other devices e.g. simpbms.
kevpatts
Been thanked: 8 times
Post by kevpatts »
kevpatts wrote: Mon Oct 04, 2021 9:28 am Anyone have some spare digital pots (IC21 & IC22; AD5160BRJZ5-R2)? My two got broken during the soldering process and I can't seem to recover them. Farnell don't sell them and RS-online are out of stock.
Got this sorted.
EV_Builder
Post by EV_Builder »
Ok question:
In the version i pulled from github there are 15 Canuser ID's added to the filter in main() but the maximum declare is 10.
Is the github just demo or full blown production version?
EV_Builder
@Damien;
I finished the table lookup.
So now we can depend charging amperage on temperature or on voltage or what we like.
The idea is that for each relation you make a table.
The C# application generates the array for you.
[Copy+Paste] and you can simply implement the degrading in code.
TableGenerator.rar
(10.05 KiB) Downloaded 365 times
The master branch is in use in 3 cars so yeah its working. Just change max_user_messages to 20. There is a major refactor underway which takes care of this amongst other things.
EV_Builder
Jack Bauer wrote: Sun Oct 10, 2021 8:04 am The master branch is in use in 3 cars so yeah its working. Just change max_user_messages to 20. There is a major refactor underway which takes care of this amongst other things.
Ok.
About the lookup shall i make it 3D? or is this 2D enough?
JockE28
Has thanked: 8 times
Post by JockE28 »
Hello, Think i have read all the post here now.. brain is overloaded, if this already is covered, please point me in that direction.
im starting to plan my first EV
Main question here:
Is the Zombieverter able to comunicate with BMS and activly sett charge limit via BMW lim module when charging CCS?
im going to use high C-rated cells that wants to be charged within a certain temperature
for eg. very low amps when cold/warm, but in the middle they can chare really rapidly
JockE28
Post by JockE28 »
JockE28 wrote: Mon Oct 11, 2021 1:10 pm Hello, Think i have read all the post here now.. brain is overloaded, if this already is covered, please point me in that direction.
Main question here:
think i missed the last pages here :mrgreen: . so no feedback from BMS at this stage? so i need to set charging rate manually in the web interface for now?
So, Damien asked me to implement regen for the ZombieVerter but instead I started refactoring :D
I now want to define interfaces for each kind of device: inverter, charger, heater and so on. Just started an inverter interface that looks like this:
class Inverter
public:
   virtual void Task1Ms() {} //Default does nothing
   virtual void Task10Ms() {} //Default does nothing
   virtual void Task100Ms() {} //Default does nothing
   virtual void DecodeCAN(int, uint32_t*) {};
   virtual void SetTorque(float torquePercent) = 0;
   virtual float GetMotorTemperature() = 0;
   virtual float GetInverterTemperature() = 0;
   virtual float GetInverterVoltage() = 0;
   virtual float GetMotorSpeed() = 0;
   virtual int GetInverterState() = 0;
   void SetCanInterface(Can* c) { can = c; }
private:
   Can* can;
Then the actual inverter class implements that interface in the usual manner:
class LeafINV: public Inverter
public:
   float GetInverterVoltage() { return voltage / 2; }
   //and so on
So instead of having a chain of if-statements that check for the selected inverter, now we just have a pointer that points to the currently selected inverter. For doing something we can simply call
speed = selectedInverter->GetMotorSpeed()
This also removes inverter specifics from the main.cpp file.
All inverter classes are statically instantiated and then the pointer is just moved to the appropriate one when inverter selection changes.
Thanks Johannes. Really appreciate this and promise I won't break any more windows:)
rstevens81
Has thanked: 29 times
Been thanked: 114 times
Post by rstevens81 »
Another daft question....
Could stm32-car (zomieverter) run on one of johu's boards or similar stm32f103? Obviously I would need to remap what pins do what. But function that wouldn't be used would I need to go through the code and remove them? I.e Prius stuff
I'm probably answering the question myself just by writing this and I need to create my own branch and play, but any experience or tips would be appreciated.
You'd need to remove all references to peripherals that don't exist. Like CAN2 and the external SPI CAN. And reduce the CAN and parameter page size to 1024 in hwdefs.h. The F103 and F107 just differ in peripherals and flash page size, nothing else.
EV_Builder
Idea:
please call your first class the base_Class...
so for example: base_InverterClass
Now inherit that class for each Type we implement and override each function in the new model with the needed content (make the functions virtual in the base class).
The basic logic of each motor can be implemented in the base class.
For example speed calculations or other stuff which depends on internal parameters.
If we build it this way a clear seperation grows between baseclass modifications (affect all classes) and modifications which are type specific.
Very pro-cool design!
EDIT by johu: redacted excessive quote, please quote selectively
kevpatts
Post by kevpatts »
polymorphism if I remember correctly.
Yes, I believe that's what I've done. You can check out the latest code here: https://github.com/damienmaguire/Stm32- ... t-refactor
CAN mod discussion moved here: viewtopic.php?f=7&t=2003
Koppi
Post by Koppi »
hello
I have a simple question
how do the components that come loose in the kit are positioned?
they are not the same parts as in the video
there is no marking on the parts
does anyone have photos of the board
or a link where it is described
thanks
peter
Thanks to the semiconductor shortage I am not getting fully populated board. The parts supplied are marked but you will need a magnifier to see some of them.
Here you will find the board layout along with designators and pin 1 marking : https://github.com/damienmaguire/Stm32- ... %20PCB.pdf
Koppi
Post by Koppi »
thank you for your message
kevpatts
Post by kevpatts »
PM me if you want close up pics of any part of the board.
et0
Has thanked: 15 times
Been thanked: 6 times
Post by et0 »
Comment about how potmin / max is handled. This confused me as it’s the opposite of most inverters that I’m used to.
Typically min and max will be *just outside* the full mechanical travel of the pedal. That way, if a value outside the limits is detected, due to open or shorted wire or even a linkage failure, the inverter can set a fault.
Then within the range you’d have a throttle map or at least some setting for dead zone, regen position, etc.
The Zombie is the other way, it wants min and max to be inside the mechanical range. Which is fine if you know that, I’ll make a note of it in the wiki.
But just suggesting it might be an improvement to do it the other way, and then you have fault detection.
Locked
