Various EV parts for sale
m.art.y
Has thanked: 38 times
Post by m.art.y »
Hi, I can offer various EV parts for sale like Tesla, Nissan Leaf, Kia, Outlander, BMW etc. chargers, motors, inverters, dcdc converters, charge sockets, leads, throttle pedals too many to list let me know what you're looking for and I'll give you a qoute.
Has thanked: 91 times
Been thanked: 517 times
Re: Various EV parts for sale
Vw GTE battery?
m.art.y
Post by m.art.y »
Bigpie wrote: Wed Dec 29, 2021 7:18 pmVw GTE battery?
At the moment have Range Rover PHEV, Jaguar iPace, Leaf 40 and 60 kwh batteries but if VW GTE becomes available I will let you know.
Cookie6000
Has thanked: 12 times
Been thanked: 33 times
Post by Cookie6000 »
Nissan Leaf 24kWh BMS?
catphish
Has thanked: 99 times
Been thanked: 197 times
Post by catphish »
I need a couple of parts to complete by BOM before beginning a build:
* Charge socket - ideally type 2
* Throttle pedal - not sure what style, what do you have?
* Brake line pressure sensor
* Brake assist vacuum pump
I may also want to grab some additional bits and pieces, though not certain yet if needed:
* Additional wiring accessories - 400A-500A fuses and contactors, safety disconnect.
* Any EVSE related bits?
Also do you happen to have an i3 LIM and DC charge port? Might be a fun addition.
Alibro
Has thanked: 505 times
Been thanked: 324 times
Post by Alibro »
I'm looking for a Leaf battery Junction box and disconnect if you have them.
m.art.y
Post by m.art.y »
Cookie6000 wrote: Wed Dec 29, 2021 8:58 pm Nissan Leaf 24kWh BMS?
There is a complete 24kwh pack with ~84k miles, might consider splitting up if I can sell in parts. What would be your offer for the BMS?
m.art.y
Post by m.art.y »
catphish wrote: Thu Dec 30, 2021 9:31 am I need a couple of parts to complete by BOM before beginning a build:
Hi, yes I can help. I'll best send you a PM as there are different options for you to choose from.
m.art.y
Post by m.art.y »
Alibro wrote: Thu Dec 30, 2021 11:25 pm I'm looking for a Leaf battery Junction box and disconnect if you have them.
Are those from inside the battery? There is a 24 kwh complete leaf pack with ~84k miles that might consider splitting up if I can sell in parts.
Alibro
Post by Alibro »
m.art.y wrote: Fri Dec 31, 2021 8:48 am
Yes mate, it's this bit plus the main disconnect if I can get it cheap enough.
https://www.azlithium.com/shopexd.asp?id=165
I'm looking for the complete assembly. ;)
Cookie6000
m.art.y wrote: Fri Dec 31, 2021 7:22 am
Thanks. I'll PM you! Would what Alibro and myself are looking for be enough for you to open the pack and sell the ancillary parts we're after?
What's a 24kwh leaf pack cost these days?
pickmeup
Post by pickmeup »
what outlander parts are you stocking?
m.art.y
Post by m.art.y »
Bigpie wrote: Sun Jan 02, 2022 11:31 am What's a 24kwh leaf pack cost these days?
Between ~1k-3k depending on mileage, age.
m.art.y
Post by m.art.y »
pickmeup wrote: Fri Jan 07, 2022 3:42 pm what outlander parts are you stocking?
Let me know what you're after and I'll check if its there. 😊
m.art.y
Post by m.art.y »
Second hand type2-type2 cable, 3PH, 32A. 55€/£50 or best offer PM
pickmeup
Post by pickmeup »
m.art.y wrote: Fri Jan 07, 2022 4:40 pm
Mainly the wiring harnesses that connect the motor to the controller and DC-DC, plus driveshafts for the rear motor/diff
m.art.y
Post by m.art.y »
pickmeup wrote: Tue Jan 11, 2022 1:54 pm Mainly the wiring harnesses that connect the motor to the controller and DC-DC, plus driveshafts for the rear motor/diff
There was a full bag of wires that had been stripped from Outlander when I have a bit more time I can take a look. Would you need wiring looms or mainly connectors? Would you have an example of which ones you need, might be difficult to recognize which ones are which now?
pickmeup
Post by pickmeup »
Hi Mate
Not sure how to embed or attach photos, but this forum thread has some good photos of the rear Inverter and DC-DC / Charger setup and the wires.
https://forums.aeva.asn.au/viewtopic.php?t=5096
Any harness and especially the correct plugs / fittings would be ideal. I have one of the cables C10002 i already, but I could do with the Harness A131 and D196?
aot93
Has thanked: 8 times
Been thanked: 49 times
Post by aot93 »
Have you got any outlander contactors?
Should be marked Omron G9EA-3
m.art.y
Post by m.art.y »
aot93 wrote: Sat Jan 15, 2022 10:26 pm Have you got any outlander contactors?
Yep, I think there is. I will double check and PM you.
m.art.y
Post by m.art.y »
Anybody is looking for a 110 or 160 kw Nissan Leaf stack or parts of it (motor, inverter, PDM, charging sockets)? Can ship anywhere within EU (no extra tax), please contact for options for shipping elsewhere. Inbox me for details 😊
m.art.y
Post by m.art.y »
If anybody is looking for charging sockets, charging cables, EVSE etc please PM. Pictured chademo and type2 set, can sell together or separately, other models available.
GVL
Post by GVL »
m.art.y wrote: Wed Feb 09, 2022 1:34 pm If anybody is looking for charging sockets, charging cables, EVSE etc please PM. Pictured chademo and type2 set, can sell together or separately, other models available.
How much for the type 2 and chademo?
m.art.y
Post by m.art.y »
GVL wrote: Mon Feb 21, 2022 5:17 pm How much for the type 2 and chademo?
Hi, if you'd let me know where would I need to post I could make you an offer 😊
