BMW i3 PDC module pinout
filipe210
Post by filipe210 »
Hi, I want to add the front parking sensors on my BMW i3. Does anyone know the pinout of the PDC module?
I already have the colors code of the wires and sensors, just need to know the pinout numbers of the module.
cloudy
Been thanked: 7 times
Re: BMW i3 PDC module pinout
Post by cloudy »
Here you go:
filipe210
Post by filipe210 »
Hi Cloudy, thanks for the answer 👍
Do you know if it is this pinout sequence?
Thank you
cloudy
Post by cloudy »
not sure sorry - you should be able to trace the ground easily to confirm pin 10. Canbus will probably be twisted together (pin 6/15) so that might help also...
filipe210
Post by filipe210 »
Tks Cloudy, I'll share what I find later 😊
Doig5710
Has thanked: 87 times
Post by Doig5710 »
If you have the loom half of the plug pull it apart, it'd almost guarantee it was numbered somewhere on the plug, usually really small though
crasbe
Has thanked: 47 times
Been thanked: 150 times
Post by crasbe »
Usually there are very small numbers in the socket as well.
filipe210
Post by filipe210 »
Thanks crasbe I found it 👍
