For the last two years, I’ve being running my DCDC with the HV negative side behind the contactor. Upon plugging in to charge, I’d set-up a manual relay logic that would close the negative contactor and enable the DCDC during charging (+ side in front of contactor). It’s worked fine until last week when it let out the magic black smoke. I don’t know whether it was the lack of pre-charge that killed it but I suspect it was a contributor.
I wish to be a little kinder to the new DCDC and intend to pre-charge. My question is, how are folk managing contactor control to enable the DCDC when charging?
P.S I do not want the DCDC permanently connected to the DC bus.
Managing automatic pre-charge of the DCDC when AC charging
- Boxster EV
- Has thanked: 57 times
- Been thanked: 50 times
- Has thanked: 166 times
- Been thanked: 413 times
Re: Managing automatic pre-charge of the DCDC when AC charging
You could install NTC inrush limiter on HV lines. You would need to calculate them for nominal current consumption, but i would bet that would spare DCDC much pain.Boxster EV wrote: ↑Mon Feb 28, 2022 6:04 pm I wish to be a little kinder to the new DCDC and intend to pre-charge. My question is, how are folk managing contactor control to enable the DCDC when charging?
https://product.tdk.com/en/techlibrary/ ... miter.html
- Boxster EV
Thanks for responding. I’ll look into those.
I was also thinking about using one of these (just to manage the charging contactor control).
https://zero-ev.co.uk/product/low-volta ... cba1185463
Not sure whether it would work or not, but I have one on the shelf to test.
- Been thanked: 1918 times
I use the pack voltage reported by the BMS and the bus voltage reported by the inverter. When the two match within a tolerance of 10V I close the positive contactor.
Not sure how much control you have and whether you have access to all necessary data
- Boxster EV
Thanks! I have the necessary inverter data mapped to my VCU, but the BMS is running at a different speed so I’ll need to overcome that…
As I’ve got the contactor controller board to hand I’ll give that a go first.
