so if it wasn't getting in the way of the rear mount I would leave this 15 pound weight on the tail of the transmission but it's so much nicer to design a mount without it, my logic goes like this there is no violent turbulent force from the internal combustion engine spinning the input shaft any more so do we really need it, but needless to say I am dumb as dirt so please set me straight on the mathephysics of this juncture
Remove the weight off the transmission or leave it on?
- Gregski
- Has thanked: 635 times
- Been thanked: 1611 times
- Uppertown
- Has thanked: 175 times
- Been thanked: 36 times
Re: Remove the weight off the transmission or leave it on?
It's a mass damper designed to help make a lexus silky smooth, I strongly suspect that in your truck the only way you would tell you if it had dropped off would be if you ran over it. (Don't weigh it in till you've tried it but I think your pretty safe losing it)
I would remove it.
As mentioned it is a tunned mass damper - mass and position would have been fine tuned by Lexus in NVH labs.
You are completely re-engineering the drive train so effectively making this null and void.
- Has thanked: 166 times
- Been thanked: 413 times
You could remove the weight and use the bolt holes to mount something there.
- PatrcioEV-ATX
- Has thanked: 42 times
- Been thanked: 67 times
hmmm.. this little discussion just showed me how to completely redesign my rear transmission mount and gain 2.5-3" of ground clearance
2012 Nissan Leaf (sold)
2016 Mercedes B250e (sold)
2023 Volvo C40
2023 Volvo C40
- Gregski
ha ha, you're welcome, and [ahem] Ramble(r) on!PatrcioEV-ATX wrote: ↑Tue Apr 19, 2022 4:14 pm hmmm.. this little discussion just showed me how to completely redesign my rear transmission mount and gain 2.5-3" of ground clearance
