Good custom made driveshafts service.
EV_Builder
Post by EV_Builder »
Wanted to give a big shout out to these guys in Poland!
Check out their website and ask them for a quote: www.motomax.pl
Nice shafts, custom made from OEM splines.
Tesla to Porsche.
I delivered them the complete shaft (shut welded) and they made a new shaft and checked the parts and assembled it all.
TheSilverBuick
Re: Good custom made driveshafts service.
Post by TheSilverBuick »
Nice!
Tremelune
Been thanked: 13 times
Post by Tremelune »
For US folk, I had a good experience here:
https://driveshaftshop.com/
Has thanked: 501 times
Been thanked: 951 times
cool, next time you're in a jam doing an EV Swap in Sacramento California, USA, Earth, Milky Way
Drive Line Services of Sacramento
704 Houston St, West Sacramento, CA 95691
dlssac.com
TheSilverBuick
I've got a local driveline shop I plan on utilizing. Basically hand them a transmission flange and say 1310 rear yoke u-joint X inches (that's right!) long with a splined slip tube in it. May put a carrier bearing step in there if the transmission is not slid far enough back.
TheSilverBuick wrote: Wed Apr 27, 2022 4:57 pm I've got a local driveline shop I plan on utilizing. Basically hand them a transmission flange and say 1310 rear yoke u-joint X inches (that's right!) long with a splined slip tube in it. May put a carrier bearing step in there if the transmission is not slid far enough back.
if you plan on using the GS450h you have no choice but to run the center bearing support, these transmission output shafts are not designed to carry the driveshaft weight/load I don't think and you risk stressing and damaging the output shaft bearing, also if you don't have an independent rear suspension you have to use a two piece drive shaft to slide in and out of itself when the rear axle articulates up and down, again the GS450h transmission does not have a sliding output shaft like the American TH350
TheSilverBuick
Good info! I knew the rear of the GS450h didn't slide, so that's the two piece is the splined slip tube I mentioned. I hadn't given any thought about the rear bearing design possibly not liking the slip tube load.
This tank definitely has a solid back axle.
TheSilverBuick wrote: Wed Apr 27, 2022 8:39 pm Good info! I knew the rear of the GS450h didn't slide, so that's the two piece is the splined slip tube I mentioned. I hadn't given any thought about the rear bearing design possibly not liking the slip tube load.
are those sui doors on that beauty, and what's her name?
TheSilverBuick
Sure are. The finest of 1967 Ford Thunderbird technology! Has a very wore out drivetrain. Figured I could sink $12k into another grumbly V8 and transmission or try the electric route.
