Sorry, I meant that for Johannes, to be clearer about exactly what terminal I was referring to.SciroccoEV wrote: ↑Fri May 06, 2022 10:22 amI had to go back to the Prius manual to work out what you were referring to.
Okay, so I think that's what I put in my diagram above, except you split the system 12v from the bus 12v.Connect your inidcator bulb between one of the phase terminals (U, V, or W) and HV+ on the bus supply.
Good so far, I have two power supplies.
Surveyyyyy SAYS?:By default, the lower transistor in each half bridge is on when the IPM is enabled, so the bulb should light on all three phases.
... nothing.
Well, 0.26v on between 12+bus and any phase. -0.26v between Gndbus and any phase.
Connecting or disconnecting MSDN to 12+system has no effect on this voltage.
I even got paranoid and swapped my gator wires just to reconfirm.
Also swapped out a new Dupont wire on MSDN, just in case. No change.
Yes. 14.6v across any phase to ground, with a 12v system supply. So, a little higher, yeah.Find the PWM signal for each phase, these are;
MUU (Blue/Black) pin 18 on the IPM, pin 9 on I-10
MVU (Blue/Yellow) pin 19 on the IPM, pin 10 on I-10
MWU (Yellow/Black) pin 20 on the IPM, pin 11 on I-10
The voltage on these connections should be similar (or I recall a little higher) than the system supply. This is the internal pullup.
Oh, and, one other thing no one's mentioned, but just to rule it out, since the lid has been off this whole time (months), I've got a jumper jammed into the enclosure switch to jumper it closed (have for months, nothing's changed). Gave it jiggle, seems solid. However, removing it has no effect on the voltage I was measuring either. Still 0.26v.
There's also a little white connector with a single wire, that connects to the case switch, that I do nothing with.
Here's my setup just in case I'm communicating this wrong.
