It is the firs time i try to produce a PCB, and i choose JLCPCB to produce the "can bus man in the middle" design from Damien.
I sent the gerbers as published in the GIT , but JLCPCB is asking me something i dont understand because my zero electronic knowledge.
I ask if somebody can help me what they are answering to me:
1.We are not sure the layer stack up. Should we make VCC= L2 and GND=L3 to proceed?
2. for the 4 big holes at the corner, should we make them as plated hole or non-plated holes ?
can bus man in the middle question
- Has thanked: 36 times
- Been thanked: 34 times
Re: can bus man in the middle question
If you just need CAN Man in the middle you can simply use arduino Due board with 2 little can transciever boards or a due shield with 2 transcievers, will work just the the same, will save you ordering pcbs. I used that setup for a while. Those can transciever boards seem to be out of stock though I still have some of those for sale.
- Has thanked: 42 times
- Been thanked: 10 times
the need is to convert can messages from a ZEVA bms system to can messages that can be send to a fast charge system . Still not decided if chademo or CCS, because i am not totally sure what is easy to implement.
is there a ino file for the arduino that can do this task ?
Yes there are a few templates available that you can modify as you need to. I use it in the exact same case where I read can messages, modify them as needed and send them out modified. Or you can use interrupts if you need a certain action to take place upon reception of certain can message.
