RS232 Serial isolation repeater
Has thanked: 135 times
Been thanked: 344 times
I need to isolate serial port of my RPM and speedo chip.
I am designing a new board. I want to use serial information i.e. from SOC device or other on the input where the output would be CAN bus telegram information. My SOC device is powered from HV and i cant connect its serial GND to car chassis.
Anyone has any idea or schematic how to implement isolation to serial bus?
Pete9008
Has thanked: 102 times
Been thanked: 350 times
Re: RS232 Serial isolation repeater
Post by Pete9008 »
There are lots of ways of doing it depending on how cost sensitive it is and how much isolation you need. A good starting point is the Analog iCoupler range https://www.analog.com/en/parametricsearch/11037#/, easy to use and reliable but do tend to be a bit of a premium price product.
Pete9008
Post by Pete9008 »
Assuming you can isolate at the TTL side and only need Rx and Tx then one of these would be worth a look https://www.analog.com/media/en/technic ... 5_2286.pdf. It still seems to be available from stock too.
Edit - changed part to one with a 5kv isolation rather than 3kv. Note - it's up to you to ensure that this satisfies your safety requirements.
Pete9008 wrote: Mon Jul 04, 2022 8:46 am There are lots of ways of doing it depending on how cost sensitive it is and how much isolation you need. A good starting point is the Analog iCoupler range https://www.analog.com/en/parametricsearch/11037#/, easy to use and reliable but do tend to be a bit of a premium price product.
Tnx, what you suggested led me to this chip ADuM1201. http://lemmini.de/RS232%20TTL%20Isolato ... lator.html
https://cdn-reichelt.de/documents/daten ... 0_1201.pdf
Seems i can directly use it with my Arduino board i only need to provide 5V DCDC supply. ADUM1201 has reversed I/Os for use as TX/RX signal.
Should be simple enough...
tnx
Pete9008
Post by Pete9008 »
Sorry, just edited my last post while you posted yours, I'd change to a ADuM2281 as it has a higher spec for the isolation voltage.
Is this for electrical isolation or for safety isolation?
Pete9008
Post by Pete9008 »
arber333 wrote: Mon Jul 04, 2022 9:14 am
tnx
That all looks good. They are very easy to use. It's just a case of choosing one that has the number of transceivers and isolation that you need and connecting it up.
Pete9008 wrote: Mon Jul 04, 2022 9:16 am Sorry, just edited my last post while you posted yours, I'd change to a ADuM2281 as it has a higher spec for the isolation voltage.
More like electrical isolation since i cant bring chassis GND and HV GND together!
EDIT: OK i made a sample design and i will put my speedo RPM serial circuit to production. Ill post my findings here...
