Matthew Dresser
Posts: 25 Joined: Fri Oct 18, 2019 9:27 pm
Has thanked: 1 time
Post
by Matthew Dresser » Mon Nov 25, 2019 1:42 pm
Hi guys,
I recently acquired the battery from a Mercedes C350 plug-in hybrid (6.3 kWh / 290V / 22Ah) for my EV conversion (for a Fiat 126) see here
https://www.matthewdresser.com/ev/conve ... troduction .
The pack as-is is too large to fit anywhere in the car, so I am breaking it down into smaller components (and plan to re-use as much of the gubbins as possible).
Has anyone been able to re-use a Samsung SDI BMS before? I would assume this stuff is used in other cars as well, but not 100% sure.
Posts: 2434 Joined: Fri Mar 01, 2019 9:15 pm
Has thanked: 211 times
Been thanked: 590 times
Post
by tom91 » Mon Nov 25, 2019 3:42 pm
first would be to track down a wiring diagram. If it has canbus it be worth not tearing the pack down to far so you can try and get some captures off the bus with the master powered up.
boekel
Posts: 135 Joined: Mon Nov 25, 2019 4:37 pm
Has thanked: 2 times
Been thanked: 25 times
Post
by boekel » Mon Nov 25, 2019 4:38 pm
I've heard it's an spi signal.
two wires between slaves and to BMU
Post
by tom91 » Mon Nov 25, 2019 6:43 pm
If you could open a slave and post pics of the top and bottom of the pcb. Then we can see what sort of chips are on it.
Matthew Dresser
Has thanked: 1 time
Post
by Matthew Dresser » Mon Nov 25, 2019 10:34 pm
@tom91 thanks for the replies (and you too @boekel) will grab some pics tomorrow evening - or as soon as work/kids/sleep-deprivation permit!
Excuse my ignorance, but are the BMS slaves within the part with the 8 connectors? (4th picture)
I'm keeping pretty much everything intact. I've split the batteries into two separate blocks but will not be ripping the cells off the cooling plates.
Post
by tom91 » Tue Nov 26, 2019 9:30 am
Slaves are the ones to which the Cells/modules wire into. so the 4 pic, the 4 'identical' looking boxes yes.
Matthew Dresser
Has thanked: 1 time
Post
by Matthew Dresser » Thu Nov 28, 2019 12:07 am
@boekel as you mentioned, there are indeed two wires between the BMS slaves.
Post
by tom91 » Thu Nov 28, 2019 9:32 am
Okay so this will most likely be ISO SPI comms. as these are LTC6804s.
Can you take the slave PCB out of the housing to check the bottom.
These should be re-usable, but someone would have to write the code to control them.
Matthew Dresser
Has thanked: 1 time
Post
by Matthew Dresser » Thu Nov 28, 2019 9:49 am
Hi @tom91,
Cool thanks for the info! Will grab some more pics of the underside of the slave PCBs.
Post
by tom91 » Thu Nov 28, 2019 3:36 pm
How is the battery module wired in?
I actually might have the right bits to talk to these slaves to hand, How good are you with Arduino?
Otherwise you could always arrange to bring some of the bits by me since your about an hour away.
Matthew Dresser
Has thanked: 1 time
Post
by Matthew Dresser » Fri Nov 29, 2019 12:28 am
Hi @tom91,
Here's a pic of the underside, not particularly interesting...
Post
by tom91 » Fri Nov 29, 2019 9:38 am
That is good because that would mear it does use the ISOSPI as expected, just need too figure out if the first module, the one with more wires to it uses normal SPI or something else.
Matthew Dresser
Has thanked: 1 time
Post
by Matthew Dresser » Sun Dec 01, 2019 12:26 am
Hi @tom91
Here's a pic of the underside of one of the slaves:
