How to find out the error
Renegate2020
Post by Renegate2020 »
Today, at the start, my bus refused to go. I looked at the web page - there is an error [8943] DESAT - STOP.
I want to understand what this error is and where there is a wiki on possible errors.
yaroslav
Has thanked: 14 times
Re: How to find out the error
Post by yaroslav »
Привет. This error occurs when the phase current is overloaded, or the signal level on the PB12 pin has changed from high to low or vice versa, depending on which controller you are using
Renegate2020
thank you
Renegate2020
Interested in the meaning of error 12164?
Maybe there is a section with decoding of error numbers?
12164 is the time when it occurred (multiply by x10 to arrive at ms after start).
Error list: https://openinverter.org/wiki/Errors
