ESP32 Based Web Interface & Data Logger
Pete9008
Has thanked: 102 times
Been thanked: 350 times
Re: ESP32 Based Web Interface & Data Logger
Post by Pete9008 »
Sound promising!
Even without FW enabled the Mtpa will let you push above base freq.
The throttle limit is the only thing I can think of. Johannes mentioned over in the simulator thread that it's not been working too well for him either so I'd disable it (I probably shouldn't have left it in but just used the latest source, the pwm bug only got fixed because mjc506 noticed it!).
Has thanked: 83 times
Been thanked: 430 times
Throttle seemed fine, I'll see if I can smash through 40kw tomorrow:D
Pete9008
Post by Pete9008 »
That would be good :) , just don't smash anything else!
If you do want to disable the limiter see here https://openinverter.org/forum/viewto ... 0#p47230 , otherwise just avoid too much throttle at high speeds. If it does cut in you will know about it as it is a bit binary at the moment :o
Did 65kw this morning without cutting out. Logger seemed to fail to mount the SD Card so no log unfortunately
Pete9008
Post by Pete9008 »
Bigpie wrote: Sun Oct 23, 2022 8:27 am Did 65kw this morning without cutting out. Logger seemed to fail to mount the SD Card so no log unfortunately
:D Wow! that's great!
How does it drive, any other differences?
Do you know whether it failed to mount or failed to start logging?
I think it's failing to mount. I've added a couple more logs from today to the Google Drive.
I've added a button to disable/enable auto logging and it's stored to EEPROM.
Pete9008
Post by Pete9008 »
Good idea.
I'll have a look at the data later.
Not sure why the card would fail to mount, you could try reducing the sdio clock speed (the command you used for auto format can set that too)
It's intermittent, so it could be a duff board, the female header pins making a rubbish connection or maybe a counterfeit card. It's supposed to be a class 10 but who knows.
Think the logs might be duff, having trouble with the converter/pulseview
Pretty pleased with the car now though, might not bother with the leaf motor upgrade.
Pete9008
Post by Pete9008 »
Will have a look at the logs once I have the PC turned on this afternoon.
Fantastic news on the performance :) Do you think 65kW is the limit or might there be a bit more to come?
I'll be upping the amps to see. Not sure what rpm it got to, but did 60 mph in first gear. I can pretty much floor the throttle now. I had one cut out while doing this but sadly the SD card must not have mounted as there's no log.
Pete9008
Post by Pete9008 »
Just had a go at opening the files.
The first one gives a few errors at the start but then decodes OK. However, when opened most of the waveforms look like the funny areas of the first log with the others fixed at zero.
The second one has a corrupted area in the header which is preventing decoding. I might be able to copy the header from the first one to get it to decode but my guess is the data will be the same as above :(
Could it be the SD card? Seems a little coincidental that there were corruptions and now it doesn't want to mount. Have you got another you can try?
60mph in 1st is impressive! What speed is the motor spinning up to? Any issues with unwanted acceleration or regen?
No idea what speed the motor was going :D My in car display tops out at 8k and I didn't have any other logging going. Would be good to calculate the frequency as part of the log.
I'll dig out another SD card to try. No noticeable unwanted behaviour, aside from the 1 cut out.
Is there any way the inverter can put itself into binnary logging mode? Commented out //binaryLoggingStart(); and still having issues loading the params. not figured out why. If I power up at the same time doesn't work. If I then restart the inverter they load.
Sending 'json' to inverter
fa
ka
{a
oa
oa
�a
Pete9008
Post by Pete9008 »
Don't believe so, if it doesn't get the command then it should just behave like the standard non logging code.
What have you commented out?
Edit - just looked at the code and can see what you commented out. Without that line the stm should never start logging.
Can't make sense of it. Seems to be only when they are powered up at the same time, but with the start commented out, it does seem to be responding with binary data.
changed to
void uart_readUntill(char val)
  int retVal;
  do
    Serial.println(uartMessBuff);
    retVal = uart_read_bytes(UART_NUM_2, uartMessBuff, 1, UART_TIMEOUT);
  while((retVal>0) && (uartMessBuff[0] != val));
and the output to serial is
Sending 'fastuart' to inverter
m
a
n
d
s
e
q
u
e
n
c
e
fa
fa
ka
{a
oa
oa
�a
Certainly looks like binary data, this doesn't make any sense :s
Pete9008
Post by Pete9008 »
Does it do on your test setup or just in the car?
That second message is the end of "unknown command sequence" so it looks like the inverter received something it didnt understand. If you let me know how you have it set up ill try to reproduce it here?
Pete9008
Post by Pete9008 »
Could be binary data or could be one has switched to the fast baudrate and the other hasn't. That would look like binary data and fit with the log. Might be the esp32 booting quicker than the esp8266 and sending the fastuart command before the stm is ready.
Try putting a few second delay at the beginning of the esp setup function.
Think I've got it now, I've put a delay in at the very end of setup to enable time for the wifi connection to be made etc and that seems to work. Not sure why commenting it out didn't work
*EDIT* Also, I need to come up with a way to no log when I'm charging. The inverter is in run mode, but forward or reverse are not selected.
I've also added a we to retry mounting the SDCard from the web interface without having to restart
Pete9008
Post by Pete9008 »
Bigpie wrote: Sun Oct 23, 2022 8:27 pm Think I've got it now, I've put a delay in at the very end of setup to enable time for the wifi connection to be made etc and that seems to work. Not sure why commenting it out didn't work
Think is was the wrong baud rate not binary. When the esp sends a command to the stm the it first checks to see if it using fast comms (both start in slow comms mode for backward compatibility), if slow it sends the fastuart command first to switch (this was in the esp8266 code too). My guess is that the esp32 boots quicker and was managing to send the command before the stm had finished its boot so the esp ended up at the fast baud rate while the stm was still on slow baud. The data would then be corrupted and look like binary. There is a handshake to prevent this from happening but Im guessing there must be a case it doesn't catch?
Good point on the charging but not too sure how to do it. Can't see a way to tell the difference between charging and driving but not having selected forward or reverse yet?
Maybe make a request for the json and look at the direction parameter before starting logging?
Pete9008
Post by Pete9008 »
Bigpie wrote: Sun Oct 23, 2022 9:01 pm Maybe make a request for the json and look at the direction parameter before starting logging?
Trouble is that could just mean you haven't selected forward or reverse yet?
Pete9008
Post by Pete9008 »
Been having some problems with parameters this morning, not sure whether it's related to your issues or not. When I try to write settings to flash the controller seems to lock up and won't respond till I do a full chip erase and reprogram. Guessing this is more likely to be a flash incompatibility on my test board but thought it worth mentioning just in case.
With the added delay is yours behaving OK now?
Nope, went out earlier and there was no logs. Didn't check why, will try again later
Just had 70kw :O hope the logs are working.
EDIT
Log out to the shops worked, the one where my shunt reported 70kw before I caught up with traffic. The log home didn't record, but at higher speed the power comes on and off, not sure if that because of some parameter or firmware, not got there before without cutting out, id usually changed up gear by then else it would cut.
EDIT again.
Lots of message lost :(
Pete9008
Post by Pete9008 »
Bigpie wrote: Mon Oct 24, 2022 2:38 pm Just had 70kw :O hope the logs are working.
:D
Bigpie wrote: Mon Oct 24, 2022 2:38 pm EDIT
EDIT again.
Is this with a different card?
If you want to stick it online I can have a look?
