Performance of gen 2/3 prius motor inverter
Timdon
Post by Timdon »
Hi, I'm new here. I come from a performance background. 5-600hp turbo charged engines with aftermarket ecus.
My wife has a gen2 prius, and one of my customers want to convert a mini cooper to ev.
My questions are,
1. How much output power and speed do we get from mg1 and mg2 when we weld them together? Assuming all other factors are optimal, Temps and voltage.
2. If I was to throw the wifes gen2 battery in the bin and replace with lithium type pack. Can we get the hybrid system to still work with the gen2 inverter controller?
Starting the engine, regen and full power with the ice and electric motor working together?
celeron55
Has thanked: 39 times
Been thanked: 136 times
Re: Performance of gen 2/3 prius motor inverter
Post by celeron55 »
2) I don't think we have the prius BMS communications reverse engineered, but if you did that, you should be able to replace the battery (just roughly match the voltage) and integrate a new BMS to keep the car operating normally and safely.
