Unfortunately this has a side-effect that when the car is moving, you get positive torque at zero throttle. This isn't surprising. The wiki states that ampmin sets a *relative* minimum amplitude, and hence when the motor is moving, it applies a much larger minimum voltage.
It seems to me that the purpose of ampmin is to apply a minimum voltage to the motor, but in reality it seems the result is just a minimum throttle position.
My question is: could we have "absampmin" in addition to "ampmin" that specifies an absolute minimum amplitude? This would allow the throttle deadzone to be eliminated when stationary by setting a more aggressive absolute minimum amplitude, but without applying so much minimum throttle at higher speeds.
