Combining multiple OEM batteries = How best?  [SOLVED]
acollins22
Has thanked: 10 times
Been thanked: 6 times
Post by acollins22 »
I was watching Damien Maguire latest video https://www.youtube.com/watch?v=qjh6rvFDR-U in which he talks about using low[ish] capacity packs from an OEM.
He talks about combining multiple packs if you need greater capacity.
Is it as simple as just joining them in parallel? In my mind, if there is any difference in voltage between the packs, things will get fruity so how should it be done?
Thanks,
Andy.
Has thanked: 82 times
Been thanked: 424 times
Re: Combining multiple OEM batteries = How best?
Make sure they're the same voltage before paralleling. I keep my parallel connection off with contactors when not driving or charging.
acollins22
Thanks Bigpie.
Does your system do any voltage checks before closing the contactors?
Cheers,
Andy.
Re: Combining multiple OEM batteries = How best?  [SOLVED]
Nope. Probably should for extra caution. I just manually checked first couple of times
acollins22
Thanks. That's great.
