ZEVA BMS24 System
- Has thanked: 4 times
- Been thanked: 4 times
ZEVA BMS24 System
Awhile back I made a bunch of BMS24 units for a project that has to monitor a ton of parallel groups. I ended up selling the battery pack and dropped it to 96 cells so I have a ton of extra BMS units left over. Since they are based on the hard-to-find LTC6802 IC I hand-calibrated and assembled them using a fluke as a reference. Different die revisions of the LTC BMS ic cause slight drifts to the voltage sense stored in registers! I don't have thermistors to test the temp sensing but I assume that it would work perfectly with the recommended sensors as per the user manual as I didn't change anything about that side of the board.
I 3D printed the enclosures using high temp ABS
I conformal coated the LTC ic to keep ingress from shorting the tiny leads together but these are NOT waterproof!
Even though I calibrated and tested every single unit. due to the safety nature of a BMS its UP TO THE USER to properly install the unit - for this reason, I can't provide any sort of warranty or support
I changed the layout and schematics to use parts that are easier/possible to source but the functionality is the exact same.
I have a total of 20x units for sale. If you are interested in more than a few (4 units) I would be happy to entertain offers.
They come with the terminal-style connectors shown in the pictures
Looking for $250 each BMS24 Unit.
I am still working on sourcing parts for EVMS V3s but I plan on selling some later.
- Has thanked: 59 times
- Been thanked: 48 times
Re: ZEVA BMS24 System
Have you or are you going to create the Zeva current sensors?
I have bought the Zeva system for my car to install once I get to that stage, so I am very glad you have created these items
Yes, I will. These require a complete redesign since the current sensor used is extremely old and very difficult to buy in any sort of quantity. I understand the CAN protocol pretty well so it shouldn't be too much work but since I don't need one for myself I haven't spearheaded the project unless there is interest in others for me to sell them.
KimchiKimKim, I love the overall design of these boards, (thank you Ian Hooper). But I have never been keen on the terminal connector with the screws only a mm away from each other. A potential short circuit could occur. Do you know of a different connector to the black ones that have say crimped ones so that there is more plastic insulation between wires?
The best way to fix concerns like that is simply with a wire ferrule crimp. I was going to replace them with some crimpable TE superseal connectors, but wiring this way is so much easier.johnspark wrote: ↑Thu Feb 02, 2023 8:42 pm KimchiKimKim, I love the overall design of these boards, (thank you Ian Hooper). But I have never been keen on the terminal connector with the screws only a mm away from each other. A potential short circuit could occur. Do you know of a different connector to the black ones that have say crimped ones so that there is more plastic insulation between wires?
Ah do you mean bootlace ferrules? that fixes stray wire strands, there would still be the issue of the screws 1mm apart. Crimpable TE superseal connectors sounds interesting. I would be happy to pay more for it.
Kind regards.
Kind regards.
So for my first car I only need those 3 current BMS modules so probably not enough for these superseal connectors...
So for my first car I only need those 3 current BMS modules so probably not enough incentive for you to invest in these superseal connectors...
Hi! Messaged you on eBay.
Just curious, will these work with the ZEVA BMS directly or do they need reflashing? It’s for expanding a battery system currently equipped with the V2 system (but I think they allow reflashing to V3) I would need 7 units. I will be doubling the 10 battery modules to 20 but I actually have 14 extra modules so there is some wiggle room for me. Thank you
Hello! These are ready to work in stock EVMS V3 but I'm pretty sure that V2 system use a different CAN bus protocol so I cannot confirm.Tito wrote: ↑Thu Apr 18, 2024 5:28 pm Hi! Messaged you on eBay.
Just curious, will these work with the ZEVA BMS directly or do they need reflashing? It’s for expanding a battery system currently equipped with the V2 system (but I think they allow reflashing to V3) I would need 7 units. I will be doubling the 10 battery modules to 20 but I actually have 14 extra modules so there is some wiggle room for me. Thank you![]()
Ok. I know about the different protocol but I'm positive the EVMS can be reflashed to V3. If not I'll source a V3 or have one made as they are open source now. But i'll take care of that.
Can you do a good deal for me with shipping 7 of them to the Netherlands?
Private messagedTito wrote: ↑Fri Apr 19, 2024 10:28 am Ok. I know about the different protocol but I'm positive the EVMS can be reflashed to V3. If not I'll source a V3 or have one made as they are open source now. But i'll take care of that.
Hi TITO,let me know if you do the uprage test on a V2 systeme , i'm in the pretty same situation as your.Tito wrote: ↑Fri Apr 19, 2024 10:28 am Ok. I know about the different protocol but I'm positive the EVMS can be reflashed to V3. If not I'll source a V3 or have one made as they are open source now. But i'll take care of that.
Sorry bit late… not to active here and just browsed some info and came across this.
I just got the (half) of the boards set up in a temporary setup in the boot of the car with the complete V3 system which I bought from the seller. Works perfectly fine and is a very nice upgrade from the somewhat outdated V2
adding the rest of the boards to the identical battery this weekend and balance the packs for a 2 string system and fit it under the car.
I still have the V2 system for a home solar battery pack (I have 4 battery modules (10kwh) extra that I cannot fit). I pulled the firmware from all the V2 stuff so I have a backup. Need to check the schematics of the V3 to see if the pins match the V2 core. The V2 has the current sensor connected directly to the core which I did not think about. So currently waiting on a PCB and the components and I’ll see if I can add it myself to the V3. Doh.
You can try for yourself to upgrade to the V3 system as I don’t think I’ll work on it anytime soon. I can send you the V2 firmware but I guess you could try to pull it yourself if you can program it too. I don’t think it appreciated that I spread the V2 firmware around the web.
I have the V3 stuff compiled too so I can mess with the can baud rate, as I think that could be the only difference.
The monitor won’t work for sure. So need to figure that out too as it can not be upgraded to V3.
Long story short: I’m no further than you at this moment.
Im slashing prices to $150 a unit.
I designed a new BMS that I plan on commercially selling that is compatible with the ZEVA system (same CAN bus format) but uses ICs that I have a 10 year commitment on so I no longer have any real use for these.
- Has thanked: 134 times
- Been thanked: 343 times
HiKimchiKimKim wrote: ↑Tue Aug 06, 2024 10:18 pm Im slashing prices to $150 a unit.
I am interested in getting 5x 24S modules if you stil have them. Let me know of the price (shipping) and availability on PM.
I am located in Slovenia EU.
