2015 Nissan Leaf - IRL
Cookie6000
Has thanked: 12 times
Been thanked: 33 times
Post by Cookie6000 »
Irish based Leaf for breaking. Heavy enough front end damage. Battery might still be salvageable.
https://www.donedeal.ie/damagedcars-for ... f/23880623
Has thanked: 134 times
Been thanked: 339 times
Re: 2015 Nissan Leaf - IRL
Cookie6000 wrote: Tue Jan 07, 2020 9:58 am Irish based Leaf for breaking. Heavy enough front end damage. Battery might still be salvageable.
I know of them, i got my motor and axles from them. They usually even have car documents to show. Good folk.
Cookie6000
Yep,
Over the months I got my 2012 Leaf Gen 1 stack, 2015 pack and the likes of the zafira pump and bits from them. Always decent to deal with
Extremetaz
Post by Extremetaz »
Same as above - nabbed both 131 and 181 complete packs from them over the last 3 years. No problems.
Break it; Fix it; Repeat;
paaa
Been thanked: 13 times
Post by paaa »
I tried to buy a motor stack from a 2015 one from them they wanted 2500, and they wanted to keep the gearbox. What sort of money were the batteries(24 and 40kw) curiously?
Extremetaz
The 131 24kWh was €2500 2 years ago.
The 181 40kWh unit cost me €3500 but I doubt they'll let the next one go that cheap, got the impression I agreed to it too easily.
They're looking for €3k for the 181 drivetrain stack complete but I reckon a good offer would take it for less.
Extremetaz wrote: Thu Jan 16, 2020 4:06 pm The 131 24kWh was €2500 2 years ago.
You mean 30kWh battery dont you? I see 40kWh from the new leaf for 7K€!
Cookie6000
I picked up my 151 24kWh pack from them in October 2019 for 2k
A few months earlier I got the 2012 Gen 1 Stack with all the wiring I could take was for 1k from them
Extremetaz
arber333 wrote: Thu Jan 16, 2020 5:42 pm You mean 30kWh battery dont you?
Nope. 8-)
Stephen Darbey
Post by Stephen Darbey »
Can I ask, if the item you refer to as the stack includes Motor, Inverter and gearbox/Diff ?
Regards
stephen
SDev
Cookie6000
The stack as they refer to it is the motor, dc/dc converter/charger and inverter. They consider the gearbox separate from the 'stack'.
Extremetaz
Stephen Darbey wrote: Tue May 19, 2020 10:31 pm Can I ask, if the item you refer to as the stack includes Motor, Inverter and gearbox/Diff ?
Regards
stephen
Taking Cookie's distinction into account, what I was referring to was the stack and gearbox.
They had the control arms there as well, and it was all sat on the OEM subframe at that time - just disconnected and dropped out.
Price I was advised was the first number they gave me when I enquired about the drivetrain assembly excluding the subframe and control arms.
As mentioned, I expect there's wiggle room in there.
