Precharge and HV circuit
nikejamie
Has thanked: 20 times
Post by nikejamie »
Hi guys
I have the gigavac gv242mab contractors and resistors.
What do the red, black, white and blue wires do?
Does anyone have a precharge and HV circuit we can follow?
Been thanked: 413 times
Re: Precharge and HV circuit
nikejamie wrote: Sat Feb 04, 2023 1:31 pm Hi guys
There it is explained....
https://www.evcreate.nl/shop/charging/g ... contactor/
Both wires leed to coils. One pair is for hard turnon and the other pair is for holding.
Has thanked: 91 times
Been thanked: 517 times
Isn't one pair the low voltage auxiliary contacts?
"This is a new old stock Gigavac GV242MAB side mount contactor with normally open auxiliary contacts. It has a rating of 400+ A and max. rated voltage of 800VDC."
Bigpie wrote: Sat Feb 04, 2023 7:18 pm Isn't one pair the low voltage auxiliary contacts?
Well in any case i suggest you check them with a light bulb in circuit.
