Yep, that would do it!
That's why I dont use UART0 to talk to the stm on my board - I'd forgotten that you do on yours.
How to program ESP32 Web Interface on V8 SDU board? [SOLVED]
- nubster
- Has thanked: 56 times
- Been thanked: 16 times
Re: How to program ESP32 Web Interface on V8 SDU board?
No idea. This is the first time I've ever tried using it, so point taken. I bought it a few months back for another project but didn't end up needing it. I'll test it as you suggest and keep the 10s timeout in mind.
Hmm, OK. I was indeed always programming the STM32 first, so I'll try programming the ESP32 first on a new board next attempt. I also realized I'm intermittently getting a different error saying, "Invalid head of packet (0x12): Possible serial noise or corruption", so perhaps this explains why.
I'll have some time later today to try these suggestions and post my results.
Owner | Founder: Westside EV
YouTube Channel
YouTube Channel
- nubster
Success!
Erasing the STM32 seemed to be the final key that allowed me to program the ESP32, and I can now access the web interface! Thank you, guys!!
Now I just need to figure out how to load and save the default parameters. When I upload the parameter file, message says it's loading them, but then they never populate under the Parameters section, and the Save to Flash button doesn't seem to work. Is the following thread relevant/should I try those builds?: viewtopic.php?t=3328&start=25#top?
YouTube Channel
YouTube Channel
- Has thanked: 102 times
- Been thanked: 350 times
Glad it's working
Probably not, all those files are FOC builds (for permanent magnet motors). Is st-link reporting the flash size correctly? If so then this isn't your problem.nubster wrote: ↑Thu Apr 06, 2023 6:05 am Now I just need to figure out how to load and save the default parameters. When I upload the parameter file, message says it's loading them, but then they never populate under the Parameters section, and the Save to Flash button doesn't seem to work. Is the following thread relevant/should I try those builds?: viewtopic.php?t=3328&start=25#top?
You should see the default parameters straight from the start (no need to load them). If you don't it suggest that the STM isn't running. You have disconnected the ESP serial programming dongle after programming it haven't you? If it is still connected it will interfere with the STM comms in the same way that the STM interfered with the programming.
- nubster
Yes, the ST-Link reports Flash size is 128KBytes (see attached pic), and I am indeed disconnecting the ST-Link and restarting the board before accessing the web interface. The red LED is flashing, which I thought indicated the STM32 is running properly, but maybe that isn't always the case. Yet when I connect to the web interface it is void of any parameters, I cannot seem to load any, nor start the inverter.
I'm flashing the v5.24.R release of the stm32_foc.hex asset found here: https://github.com/jsphuebner/stm32-sine/releases. I noticed the name of the asset doesn't seem correct since as you said, it's not FOC but Sine. Is this just a simple typo, or am I flashing the wrong firmware?
FWIW - I encountered a similar behavior a few times before while installing a V7 board. I was working on the wiring harness, and "all of a sudden" the interface stopped auto-updating. When I hit refresh all the parameters were gone and I could not load them or start the inverter. The inverter was basically non-responsive until restarting it, which fixed it and all the parameters were back. I chalked it up to me working on the harness since once I had everything wired up and running properly I haven't seen it again.
YouTube Channel
YouTube Channel
Doesn't look like the flash size is you problem so the other thread isn't relevant.
You probably need to go back to an earlier version (5.00??) to find a pre-built version of the sin code (the only recent changes have been to the foc version). Also worth checking catphish's current control code if you don't need regen (viewtopic.php?t=3086).
You are using the johu fork of the ESP code aren't you https://github.com/Pete9008/esp32-web-i ... /tree/johu? The master version won't work on your board as it uses a different comm port pinout.
One other check worth doing is to connect just the Rx line (and GND) from you serial dongle to the ESP programming header and then watch what is received in a terminal program. The ESP should send the 'json' command each time you update the web page (should see this if connected to the Rx line on the pin header) and the STM should respond with a long block of parameter data in human readable format (should see this if connected to the Tx header pin). The baud rate will either be 115200 or 921600 depending on whether the switch to fastbaud rate has worked.
- nubster
Ok, I finally got it!Pete9008 wrote: ↑Sat Apr 08, 2023 10:09 am You probably need to go back to an earlier version (5.00??) to find a pre-built version of the sin code (the only recent changes have been to the foc version)...
I was using the stm32_foc.hex asset because that was the only one I saw in the latest release (v5.24.R), but I see now if I explore older releases, there is a stm32_sine.hex asset available. After switching to the johu branch of the esp32-web-interface and downloading & flashing the stm32_sine.hex (v5.20.R-2), I am good to go.
So I was using the wrong STM firmware AND the wrong ESP branch.
This was quite the journey for me, and I learned a lot! Thank you and @johu for guiding me through everything. I took a lot of notes and am happy to contribute a how-to guide detailing the process of building a Tesla SDU board from scratch. If this is something you think the community would appreciate, please let me know where to submit a PR. Assuming https://github.com/jsphuebner/Tesla-Front-Drive-Unit would be the most appropriate, but let me know otherwise.
YouTube Channel
YouTube Channel
- Has thanked: 344 times
- Been thanked: 1486 times
Yes, feel free to add it there.
might eventually make sense to shell it out as it's the same procedure on all esp32 based oi boards
- nubster
YouTube Channel
YouTube Channel
