Testing FOC for synchronous motor
Been thanked: 1914 times
Re: Testing FOC for synchronous motor
Great to hear, thanks for testing!
Yes fixing regen is my next and hopefully last homework :)
PoloLbricolo wrote: Fri Nov 08, 2019 2:14 pm attached are the parameters i used
Erm, this exhibits a catch of the web interface: you have to hit "Refresh" to download a recent parameter set (frqfac=0 in yours). Maybe something I should fix.
PoloLbricolo
Been thanked: 12 times
Post by PoloLbricolo »
Did some more testing today, drove about 30km, and the car feels really good.
Exept when i stay at about the same speed for long periods of time, typically above 4000rpm (60kph) and for more than a few minutes, the "cruise control" effect comes back, but this time it doesn't comme off, (i stayed a 65kph for a minute on flat road with my foot off the throtle)
It may be because my syncadv parameter is set to 11, and/ or the frqfac is set to 50, i run a 250v DC.
Also at maximum speed (8000rpm or 120kph) the behaviour is quite strange, i have to stay full throtle to maintain speed and if i comme off just a little, my speed comes down to 100. Mybe it's normal, but it feels stange.
Anyways, i'm leaving the car for a moment (the car is in Romania, and i work in France now) so no more testing for me for a while, hope you get the last bug corrected so we can start to chase more power ! :D
Thanks for you hard work.
Yes I think I know what that is.
if (y < maxY && y > minY)
   esum += err;
So it will stop accumulating when the output saturates but it will never de-accumulate either! I've changed that, will test myself.
Strange behavior at 8000rpm might be solvable with higher fwkp and other value for syncadv
doobedoobedo
Post by doobedoobedo »
Did some bench testing today, seems a lot better.
I don't have any regen. When I come off the throttle at max rpm (1200rpm running at 60V) there is a sudden drop in rpm followed by a long slowdown. I need to play with parameters maybe?
Could we have a brief explanation of the new params and their expected function?
eg. throtcur seems to be higher = faster acceleration (and stronger regen?)
doobedoobedo
Just uplodaded the new code and coming off throttle is much better. Big thumbs up from me :).
No parameter description yet, as they are not matured yet. Don't want to describe parameters that vanish in the next version.
throtcur might stay. It is A/% throttle. So throtcur=4 means 400A at 100% throttle.
doobedoobedo
Ah OK, I'm drawing pretty low currents with my low voltage and no load on the bench, I did notice faster ramp up with throtcur = 3 over throtcur =1. Variable max power/torque is something I want to implement in my car anyway, so a max amperage is perfect for that I think.
I appreciate that things are in a fairly rapid dev cycle at the moment, so no worries about the changing parameters for now.
PoloLbricolo
Hi all,
Any update on the bugs solution?
Unfortunately no, winter and contracting is keeping me away from more coding/testing.
Ideas to test next: when transitioning between acceleration and regen (at speed) first ramp up/down to 0 torque request until the PI loop has settled, then go on ramping to the desired direction. Hopefully thats fixes the roughness.
In terms of high speed operation: check what q-current is being calculated on unwanted regen, i.e. raw back-emf pushing current into the battery through the inverters diodes. If this shows up as q-current I can add an other P or PI-regulator that counteracts unwanted q-current by outputting a field-weakening d-current. Hope that makes sense ;)
So I plotted iq at high speed regen yesterday and indeed it exceeds the -50A setpoint grossly (down to -220A). I have added a P-regulator to increase field weakening current if iq cannot be maintained. It does do that as expected but still fails to decrease iq. Not sure what the deal is.
When dialing down regen to -5% surprisingly I got less undesired regen. Will keep investigating.
Apart from that driving works really well.
I corrected one bug in FOC code: the frequency dependent offset was not limited to the controllers maximum output, typically [-37813, 37813]. So once the offset surpassed that limit the integrator would wind up to counteract. Offset is now limited. Haven't drafted a new release yet.
There is also a new test mode for FOC that allows you to manually specify and id and iq set point, e.g. for finding syncofs. It's still a bit dangerous as the speed limiting code is not in effect. Given enough field weakening current I'm not sure where the physical limit for the motor speed will be, so careful, keep your hand on the ignition key!
PoloLbricolo
Great news :)
dima
Post by dima »
Attempted to build (under Windows) Can't seem to find timer_get_ic_value from inc_encoder.cpp (searched all files)
Used your copy of custom libopencm3 and libopeninv
EDIT: Changed line 587 ...compiled OK.
 int measTm = timer_get_counter(REV_CNT_TIMER);
doobedoobedo
Builds fine for me (linux)
did you run:
make get-deps
I wrote a little script:
$ cat build.sh
#!/bin/bash
make get-deps
CONTROL=FOC make clean
CONTROL=FOC make
dima wrote: Mon Jan 20, 2020 10:55 pm EDIT: Changed line 587 ...compiled OK.
Of course thats not the same but then this code won't be used in FOC mode most likely.
Just studied another paper on anti-windup and came across a chapter where he calculates some ideal Kp and Ki values for the id and iq controllers. Surprisingly he ends up at K p = 16.06, K i = 20200. So really high Ki. Hmm, maybe I should try that too.
Paper here: http://www.jcee.upc.edu/JCEE2008/pdf_po ... windup.pdf
Alright everyone, this is crazy! I just drove with curki cranked up to 20000 and all the various kludges that I added in the last months disabled. Result: awesome!
No unwanted regen, smooth acceleration to 9000rpm (didn't dare spin faster with my vibrato coupler), no over current trips on wheel spin. It just drives.
All that pain because I didn't have da ballz to crank up the integral controller gain :D
Did a quick measurement and reported a power peak at 110kW, 20 kW regen. I never sniffed cocain, but I'm sure this is better 8-)
By disabled kludge I mean the frqfac parameter, the separate regen controller and the ramp between the two. All unnecessary.
Parameter attached, will release the cleaned up firmware in a minute.
Leaf 2020-01-31.json
(1.15 KiB) Downloaded 382 times
doobedoobedo
Awesome :D
Cocaine is overrated.
Alexstarex
Post by Alexstarex »
All I ran to buy an engine from Nissan Liaf).
johu respect
kiwifiat
Post by kiwifiat »
johu wrote: Fri Jan 31, 2020 4:34 pm Alright everyone, this is crazy! I just drove with curki cranked up to 20000 and all the various kludges that I added in the last months disabled. Result: awesome!
That is really great news, persistance and research pays dividends. Thank you :)
Kevin Sharpe
Been thanked: 10 times
Post by Kevin Sharpe »
Congratulations Johannes :D
omegon
Post by omegon »
:D :lol: :twisted: ;) Party on!!
Thank you all :)
Now on to traction control -> see Touran thread
More testing today. There are still some occasional trips in the high rev range when changing from full throttle to full regen.
I have removed the bus voltage based field weakening controller and only left the "crossover-controller" in. That is if iq can't be reached, id will be increased (well, decreased, as it's negative).
I also added a frequency dependent factor to curki. So with increasing motor speed it will increase integral controller gain for better response in that region while maintaining the car calm in the lower rev range.
I tried a filmed test drive but acceleration is so hard now that the camera topples over. Plus two cop cars came the other way which, well, is a bit problematic right now. So maybe not a good idea to publish the video ;)
Been thanked: 411 times
johu wrote: Thu Feb 06, 2020 11:10 am More testing today. There are still some occasional trips in the high rev range when changing from full throttle to full regen.
Nice! Maybe you could go to some abandoned airfield and try there...
So do you think i can use FOC brain with TWO power sections now? I would be driving IGBTs from the same pwm channels but i would parallel current sensors up to 3K3 pulldown resistor. My theory is any difference in IGBT output would be shown in sensor readout leaving centerline. Would be interesting to try. Is the current reading fast enough to sense this?
