Wanted: Power posts for Lexus GS450h inverter.
acollins22
Has thanked: 10 times
Been thanked: 6 times
Post by acollins22 »
Does anyone have a pair of the brass power posts required for the GS450h inverter to squirt power in past the IGBT and Coil?
Thanks,
Andy.
sigdigits
Has thanked: 31 times
Been thanked: 8 times
Re: Wanted: Power posts for Lexus GS450h inverter.
Post by sigdigits »
I bought some brass stock to make some, and when I finally get to it I have enough for a spare pair... I’ll post back when I make them
sigdigits
Post by sigdigits »
I got a good start making the power posts before someone pointed out that brass has much less conductivity than copper (about 1/3)... I'm not sure if I'll continue down that path, as they also pointed out that using readily available aluminum spacers with a longer bolt will be a LOT less work.
Has thanked: 180 times
Been thanked: 372 times
sigdigits wrote: Sat Jun 17, 2023 9:37 pm …..aluminum spacers with a longer bolt will be a LOT less work.
Watch out, don’t want to be mixing dissimilar metals, especially for a HV connection. Lots of galvanic corrosion
Copper and aluminum are not a good combo.
sigdigits
Post by sigdigits »
Bratitude wrote: Sat Jun 17, 2023 10:36 pm Watch out, don’t want to be mixing dissimilar metals, especially for a HV connection. Lots of galvanic corrosion
Do you know what are the OEM bolts made of? I'm pretty certain they're neither copper OR aluminum, but the buss bars are definitely copper
copper or zinc plated steel
