Hi all,
I'm wanting to send CAN messages, using the web interface, to some speedhut gauges to show MPH. I've been told I can use the 'speed' section of can messages but I don't know where to start.
Why tyres are 185 65R15s (it's a vw camper).
Please give answers for the 4 boxers on the web interface.
MPH through CAN from tesla SDU to speedhut dials
- Has thanked: 75 times
- Been thanked: 313 times
Re: MPH through CAN from tesla SDU to speedhut dials
Do you know the Can ID the gauges expect to see the speed message on and the format of the message?
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Outlander charger
Chademo Charging
- Has thanked: 106 times
- Been thanked: 231 times
https://openinverter.org/wiki/CAN_communication
Towards the bottom section "Mapping Values through the web interface"
This again is open inverter so there is no variable road speed gain at the moment. So you need to bake this into how you setup the RPM / Speed (motor) to convert it to a vehicle speed value.
Did Zero-EV/Fellten stop selling Tesla Drive units?
- Has thanked: 170 times
- Been thanked: 1082 times
Yes, say the display expects road speed in mph as an integer and the speed to mph ratio were 100 (1000 rpm equals 10 mph) then you'd enter 0.01 as the gain factor. Since 5.27.R the gain can be more or less float so that is now possible.
don't be surprised that after setting it up the gain will show as 0. That's because the print routine is still limited to 5 binary digits (and thus roughly 1.5 decimal digits)
Not sure,
I used to have
CAN ID 599
Position 0
Bits 16
Gain 10
This was under a parameter titled 'roadspeed'
And what was "roadspeedgain" ?
Sorry, I didn't have a setting for roadspeedgain
Upload your .JSON for the Zero-EV firmware it is in there for sure.
Line 10 "roadspeedgain"
