For Sale: Hyundai Ioniq 5 battery pack modules
****** UPDATE - modules only. Pictures further in the thread *******
This is from a rear wheel drive Hyundai Ionic 5 with 124 miles on it - like new. It is composed of 30 modules, which are designed to be thermally managed by sitting on a coolant/heating plate (the entire bottom of the battery). Each module is made of 12 NMC811 pouch cells in 6S2P. 21.8V nominal (25.2V max), 2.41kW, 111.2Ah. I believe the batteries are by SK Innovations.
Individual module dimensions are:
without mounting tabs - 15.25"x5.25"x4.25"
with mounting tabs - 16 7/8"x6.25"x4.25"
The tabs overlap to allow bolting 2 together with a single bolt, so the effective width is really 5.75" not 6.25"
For example, a block of 4 you see in the picture is 22.25"x16 7/8"x4.25" including the tabs
Any of the major BMS should work with these. They have connectors exposing 7 pins so you can measure (and balance) all cells.
Located in Northern Virginia.
$6,000 for the full pack, $200/module
*I have additional components from this car if you are interested, such as the motor sub-assembly, ICCU, DC-DC convertor, CCS charge port and cabling, VCMS, high voltage junction box, etc.
More info
More info
- EV_Builder
- Been thanked: 37 times
Re: For Sale: Hyundai Ioniq 5 battery pack - 72.6kWh
Used is a big word; but there are commercial products making this pack useful for storage etc.
Sorry, I don't seem to be getting notifications, so did not see this. The module dimensions are
hth
charles
hth
charles
Last chance to buy a fully assembled pack. I will be pulling the modules and selling them individually for $200 each.
Canbus data shows the cells to be extremely well balanced and less than a a single full charge/discharge cycle of use.
- EVSwap
- Has thanked: 111 times
- Been thanked: 91 times
How much for shipping to 80465 for the whole pack?
-Jimmy
EVSwap Conversions
EVSwap Conversions
Is this still for sale? I'm interested in six modules.
Sorry I am not getting notifications on this thread for some reason, and I have already mostly dismantled the last battery now. If you don't care about the battery chassis I can research shipping options if I pallet up the modules (would be something like 3x2x3'. If you want the chassis I think shipping is likely in the $800-1000 range from what I recall researching it when I first got them and I can bolt the modules back in and seal it back up, but I'd need payment before doing the work again, and I am dismantling them because they take up far less space this way and I need to room, so it would need to be soon
PM me if you want to discuss.
Yes, PM me with your location and we can work out the details.
To be clear I have multiple packs, a total of 52 modules available at the moment (one full pack and 22 left from another)
