I am going through Damien's video for bench testing the "LARGE DU LOGIC BOARD V6" and wanted to confirm a couple things before I try power it on for the first time.
1. What size fuse is reccomended for the 12V power input?
2. (Maybe a redundant question) - When powering it up from a benchtop power supply set to 12v, what current limit should I use?
3. Is there a decent startup guide somewhere for using this board? So far I have only come accross the video that Damien put out 3 months ago:
https://www.youtube.com/watch?v=ZvlzGm709zg&t=2011s
Thanks!
- James
12V Fuse and Current Limit for Large DU Logic Board V6
ImportFanatiK
- Has thanked: 6 times
- Been thanked: 1918 times
Re: 12V Fuse and Current Limit for Large DU Logic Board V6
1. Fuse protects the wiring, not the circuit. So if you wire it up with say 1mm² you'd fuse with 10A or so
2. I'd say about 3A to supply surges
3. https://openinverter.org/wiki/Tesla_Mod ... %22LDU%22)
