Is there a reason why it's positive number in Parameters page (https://openinverter.org/wiki/Parameters) or, is my and many others parameter values just plain incorrect?
brkmax/offthrotregen negative or positive?
- mane2
- Has thanked: 50 times
- Been thanked: 61 times
In Wiki, it says brkmax / offthrotregen value is positive 0-100%, but almost all parameters I've seen (including the one I use) it's negative. Also reading the code, I think it needs to be negative. (max -100%)
- mane2
Re: brkmax/offthrotregen negative or positive?
To add confusion, in source code test/test_throttle.cpp has:
Throttle::brkmax = 50;
But then again, I think test source code is outdated.
I'm quite sure the value needs to be negative, but would like to get confirmation on this. Then Wiki parameters page could be updated.
- Been thanked: 1918 times
Oops, yes please update!
Thanks for checking.
- mane2
Thanks for confirming. Updated! https://openinverter.org/wiki/Parameters
