Do you have an inverter recommendation that converts the 250-400V voltage range to 220/230V 50Hz voltage range?
It will be used with Li-on battery pack
Inverter for lion battery
- Been thanked: 1913 times
Re: Inverter for lion battery
Moved to renewables.
You gotta be more verbose here. What power level for example? Which comms interface?
ok.
Actually there is 48V input to 230Vac inverter for li-on battery. Im looking 250-400V input range.
Also generally inverters for solar panels. They are converting DC to AC. Im looking for li-on battery.
communication is not imported and not neccessary now. Just Im looking an inverter that converts the 250-400V voltage range to 220/230V 50Hz voltage range.
thanks for feednback.
- Has thanked: 360 times
- Been thanked: 249 times
Will likely need some amperage / kw goals.
A rotary phase converter setup but with a repurposed ev motor on the input side could work well to get clean power out the other side. Likely much cheaper options but also likely not as simple.
