[WIP] Mercedes 310E (310D campervan) - GS450H/GS300H
aot93
Has thanked: 8 times
Been thanked: 48 times
Re: [WIP] Mercedes 310E (310D campervan) - GS450H/GS300H
Post by aot93 »
Jacobsmess wrote: Fri Dec 08, 2023 10:58 pm I've gone through and checked wiring and continuity this evening but nothing but I also checked the torque Vs pot and there is no torque request with pot change.
Did you check inter-pair resistance? Should be 60ohm across each pair?
I had problems getting the motor to spin without solid ground connections between inverter, motor, and zombie.
Has thanked: 425 times
Been thanked: 123 times
Post by Jacobsmess »
I did and got 128ohms across each pair measuring the same end of each (unplugged zombie). I thought it should be 120ohms....
I'll try the ground but have tried with an alumiun bar connecting inverter and transmission and signal wire shielding to inverter and then a wire connecting inverter to the negative of the battery.
Has thanked: 83 times
Been thanked: 430 times
120 on each end, so 60 if both zombie and inverter connected
Has thanked: 211 times
Been thanked: 593 times
Jacobsmess wrote: Sat Dec 09, 2023 12:09 pm I'll try the ground but have tried with an alumiun bar connecting inverter and transmission and signal wire shielding to inverter and then a wire connecting inverter to the negative of the battery.
Aluminium bar has oxide on it so not a good connection. Use a bolted wire connection. By the battery do you mean 12V supply to the Zombie?
tom91 wrote: Sat Dec 09, 2023 12:26 pm Aluminium bar has oxide on it so not a good connection. Use a bolted wire connection. By the battery do you mean 12V supply to the Zombie?
It's brand new anodised bar I'll change it for a wire.
Currently using a 12V battery with a 12V PSU connected in parallel. The inverter is grounded to the battery terminal.
Resistances on zombie plug across signal pairs. All around 120ohms
We have a winner!
Put some galvanised steel wire, between everything and also moved everything onto a bigger battery which may or may not have helped. Anyway, we have liftoff!
Edit: I think the change to a bigger 12V battery might have done it tbh as removing the wire that grounds everything hasn't changed anything and it still spins.
Now how do I get gauges to show motor rpm ......
Jacobsmess wrote: Sat Dec 09, 2023 2:43 pm Now how do I get gauges to show motor rpm ......
I would absolutely not be worried about any of this right now. Doing anything not on a propper setup it is pointless to get values from it.
Current zombie code gets mg2 speed and displays it as speed.
First wiring harness (half) made up for the oil pump controller....
crasbe
Has thanked: 47 times
Been thanked: 150 times
Post by crasbe »
The cloth tape isn't always suitable for outside applications, it might go moldy.
crasbe wrote: Sat Dec 09, 2023 10:42 pm The cloth tape isn't always suitable for outside applications, it might go moldy.
Ah that's a bit annoying but thanks for the heads up. What would be a suitable alternative tape-wise? It's be nice just to rewrap the existing cloth in something rather than remove it completely if possible. I may add conduit also at a later date when installing.
crasbe
Post by crasbe »
Get some good quality PVC tape from a reputable brand. Coroplast or Tesa for example. The cheap tape becomes "slimy" rather quickly.
You can get cloth-like tape which is suitable for exterior applications like TESA 51036 (recommendation from Tom91 :D ).
Tesa has catalogues which you can go through and find good tape for your desired applications.
Woodfie
Has thanked: 221 times
Been thanked: 95 times
Post by Woodfie »
There is 3m self amalgamating silicon tape, that when stretched so the dimples dissappear and bound, is extremely durable.. this maybe suitable to overwrap your loom.
PatrcioEV-ATX
Has thanked: 42 times
Been thanked: 67 times
Post by PatrcioEV-ATX »
How does your tach currently receive the signal for RPMs? I am sending MG2 Spd to an Arduino and displaying that on a custom Nextion display. But knowing how your tach works is the starting point.
2012 Nissan Leaf (sold)
2016 Mercedes B250e (sold)
2023 Volvo C40
PatrcioEV-ATX wrote: Tue Dec 12, 2023 7:47 pm How does your tach currently receive the signal for RPMs? I am sending MG2 Spd to an Arduino and displaying that on a custom Nextion display. But knowing how your tach works is the starting point.
:D tach!
My van has temp, fuel, Speedo and an analogue clock!
More just wanting to display stuff on the web interface gauge for bench testing ATM.
Do any UK people have a good recommendation for cheap sources of automotive wiring? I'm wiring up the oil pump controller which is 4mm diameter (including insulation). Wiki suggests the oil pump could pull up to 50A. Obviously eBay but I'm wondering if given the source the markup might be much higher, anyway..... Any recommendations?
I have used these webstore many times, good pricing and good quality.
https://incardesign.store/
So I turned the motor and inverter on today to do some spinning and see if I could get mg2 and mg1 rpm using a BIN from Bigpie, which worked for a little bit, then the motor started running really sluggish and weirdly. It might be low HV battery so I'll give it a charge but not sure what else it could be.
After checking the HV battery voltage, they all see ok (5x12V batteries sitting at 12.6V each)....
It's possible the throttle wiring may be a little dodgy so I'll have a play with that tomorrow and hopefully get it back to spinning properly.
Woodfie
Post by Woodfie »
If throttle wiring is okay, check resolver signals for ref waveform and sin , cos waveforms are clean.
It happened suddenly so I'm a bit confused but potentially the clutch packs have slipped as I was stupid and ran it fastish without the oil pump running. I'm going to wire up the oil pump controller once wiring arrives and hopefully that'll sort it. I tried again today after charging the 12V batteries and it ran a little better but still not as it was before.
Woodfie
Post by Woodfie »
With your subject title, Gs300h part, are you still considering it?
Am contemplating using L210 trans from gs300h in a campervan application with around 4.1 :1 diff ratio, and figure will be Mg2 12500 rpm @ 100kph.
Have seemingly managed to load free on hoist get to max 14000 rpm, after some conjecture, with mistaken ratios.
Think you have explored this avenue, but keen to hear your current views on it.
Woodfie wrote: Tue Dec 19, 2023 10:00 am With your subject title, Gs300h part, are you still considering it?
Yes still considering it but I wanted to test the safer option first. After trying to manoeuvre the GS450H onto my workbench however I'm a lot more tempted by the GS300H again.
andybpowell
Has thanked: 217 times
Been thanked: 257 times
Post by andybpowell »
the 300h is not that much lighter :lol:
andybpowell wrote: Tue Dec 19, 2023 1:50 pm the 300h is not that much lighter :lol:
90kg Vs 120kg, I know which I'd rather try and haul around haha
