Outlander rear motor and inverter
- Has thanked: 8 times
- Been thanked: 47 times
Re: Outlander rear motor and inverter
so this weekend got it driving up and down the drive. no coolant at that point so a very short slow run but proves it all works. Umpteen jobs to do to get it road ready but good progress and pleased to have it mobile again.
E46 touring
BMW 9kwh & 12kwh packs
- Has thanked: 83 times
- Been thanked: 430 times
Awesome progress
- Has thanked: 134 times
- Been thanked: 342 times
I am really interested at your experience for when you change 0x287 byte6 from 03 to 00. What happens if you are at speed? Would the byte6 03 return cause a jolt? How does it feel when you touch the brake at speed?
EDIT: I am thinking of using "normal" input to trigger byte6 change in winter independently from brake pin. E.g. using a separate flag in the loop.
"sport" mode would drive without this loop.
tnx
i'll let you know when i get it out on the road.arber333 wrote: ↑Sun Dec 17, 2023 6:45 pm I am really interested at your experience for when you change 0x287 byte6 from 03 to 00. What happens if you are at speed? Would the byte6 03 return cause a jolt? How does it feel when you touch the brake at speed?
tnx
from my previous post i only put this in because in one direction on the bench the motor was reluctant to spin down. However that is now confirmed as the direction i don't use so if there is a jolt on disable i think i will try removing that code.
Should have it road tested in a day or so.
E46 touring
- Has thanked: 22 times
- Been thanked: 133 times
I suggested clearing byte 6 based on CAN logs, but after looking in a bit more detail it only happens at low speed. Two examples in the log file were 30 rpm and -27 rpm, at higher speed it was 0x03.
i'll have a play with setting that byte
For others that have done this, i have seen various throttle strategies from damiens pedal maps using rpm & torque request lookup, to a more gradual increment torque request each loop through the 287 send, and dual rate so first part of travel has less 'gearing'.
At the moment as i've just written it, pedal position maps to torque request linearly. What is the experience of people here with different map strategies and drivability that results in the best feel ?
E46 touring
I figured it would cause a jolt at high speed. My Peugeot Lebowski drive does cause quite a jolt even though it immediately returns to operation at high speed.
EDIT: I might think of adding a loop to turn b6 to 00 for two conditions:
1. with throttle pedal at or around 0 position and; at low speed 20RPM/-20RPM;
or;
2. with brake pressed and; at low speed 20RPM/-20RPM;
and i would add when you hit the brake
i'll try some strategies and report back
E46 touring
tonight with the coolant loop working i went half a mile with no issue.
Tomorrow i need to hook up the temperature reporting etc before i go any further afield but it is getting there.
E46 touring
so today did over 7 miles in two trips. after 1st trip i looked at the log and realised i had the throttle scaling wrong and was only asking for abut 75% of torque.
Fixed that and went for another spin, all good. Can put foot to floor anytime with no worry about inverter trips. I would say its quite a bit stronger from standstill where i think the prius inverter was current limited or tripped, and about 10% up all other areas.
To answer the question posed about disabling the inverter when off the throttle and would this cause a jolt - not a bit, feels fine with no fancy pedal mapping at all. The issue with disabling the inverter on zero throttle will of course be no regen available, but that comes later...
E46 touring
Excellent! Thank you.FFMan wrote: ↑Wed Dec 20, 2023 7:07 pm so today did over 7 miles in two trips. after 1st trip i looked at the log and realised i had the throttle scaling wrong and was only asking for abut 75% of torque.
Can you explain how did you scale up (from where) throttle and what you are referring to "no fancy pedal mapping". Do you mean you used linear throttle? With zombieverter?
I am wiring for aot93 teensy VCU and i will add byte6 control to brake for sure. That should in fact be the certification requirement for any ESD, ABS or other drive enhancement in a car.
tnx
so i have PotMin and PotMax variable define the usable range of throttle in the car, so
throttlePercent=map(throttlereading,PotMin,PotMax,0,100)
then map the percentage to 0-200nm torque, add 10,000 and send
I don't know what a093 is. I am using Teensy 4.0 for vcu
If you zero byte 6 you can't set regen so i will abandon that approach shortly but for initial testing it was a good move.
E46 touring
aot93 is the author of the teensy 4.1 VCU and code here viewtopic.php?t=2167FFMan wrote: ↑Wed Dec 20, 2023 7:52 pm so i have PotMin and PotMax variable define the usable range of throttle in the car, so
I got the hardware and firmware and i am trying to get it working in my Mazda.
So which firmware do you use if i may ask? Did you develop your own github?
tnx
i wrote my own code based on knowledge gained by looking at other code. I prefer to do that so i fully understand how it works.
Mine is very simple based on a custom PCB a friend had made for it. Basically a Teensy 4.0 and can transceiver and some resistor dividers to take the 12v start signal.
Happy so share any details and I have some spare unpopulated PCBs about as min order qnt was 5.
E46 touring
- DkubusEV
- Has thanked: 143 times
- Been thanked: 15 times
FFman I'd definitely be interested in one of your boards, and if you're willing to share your code ? Please shoot me a message so we can exchange details and make arrangements for payment too. Cheers mateFFMan wrote: ↑Wed Dec 20, 2023 8:22 pm i wrote my own code based on knowledge gained by looking at other code. I prefer to do that so i fully understand how it works.
1998 Mercedes R170 SLK gs450h project
2003 Smart-Roadster hillclimb EV (DC)zilla2k
1976 Purvis-Eureka EV kit car
2011 Ford focus EV (DC)Soliton1
1990 Daihatsu charade G100 3 door DC conversion.
for some reason i can't PM you - it says user does not exist even though it finds you in the directory so :-
Hi
you're welcome to a board but you can also have the files as i see you are down under, maybe you have nearer fab places or i can post one ?
Can you smt solder ? There are a few components to mount. Failing that i might be able tp persuade my mate to assemble one for a few beer tokens.
What car is this going in, i ask because we have an E46 variant which combines dash control and VCU on one board to save the Teensy count.
I've attached the code. It works but has no frills, it assumes contactor control/precharge is done elsewhere like mine is, and is on a separate can bus to the Outlander charger as there are some common can ids in use.
It just has throttle pot, brake and start in and can which talks to OEM inverter, and also sends out a periodic 0x555 message to my other Teensy that controls my Nextion display but you can remove that.
It's still subject to a bit of refinement but it works as is
- zombie_code_v1-T40Prod.zip
- (136.7 KiB) Downloaded 1084 times
E46 touring
Thank you much for your files.FFMan wrote: ↑Wed Dec 20, 2023 9:51 pm ....
If i may ask... do you perform precharge at all.
I started to develop my system based on esp32 chip. While i set my system up for 2s precharge before drive and charge process i cant get this to behave in a stable manner. Not all cases provide prechage on starting trigger. Can you elaborate on how you perform that process?
my contactors are controlled by some timed relays, not by software as such. So if i turn the arduino on for charging, or turn the ignition key the relays fire up in order, negative & precharge, after 3 secs, main positive comes in, and half a sec later precharge drops out.
this was chosen in the early days as i tried to keep my code off the critical path for running, but having dropped the openinverter board in favour of my own vcu that design parameter has gone out the window anyhow. I think mainly i was trying to avoid a board lock-up or load of new s/w dropping the contactors
E46 touring
When i couldnt get any RPM information from my VCU i started to investigate CAN reports. I noticed telegram 0x289 byte7 wouldnt report disable condition the same as we have it documented...
Next i investigated RPM commands and they seem different as well.
I then went on and recorded CAN log of my inverter and DCDC in operation.
1. I could confirm DCDC is reporting as standard as is the case with charger part.
2. Heater does work exactly the same as before.
3. Inverter on the other hand wouldnt report in the same format as we know. My inverter is P/N 9410A163.
However i can see inverter will still respond correctly to torque request.
I have run my motor at power and recorded inverter report. I attach it here.
Please guys can you let me know which P/N you have that is working with OEM torque commands? I figured it must be P/N 9410A081 asit is the only other inverter i see being sold.
EDIT: It seems i messed up with CAN mailboxes and didnt notice there was one mailbox for two things and this may have interfeered with CAN reading. I get charger reporting now as well as DCDC and inverter temperatures. CAN bus should be the same between inverters. I will see what can i do about torque tomorrow.
- rpm1.txt
- (2.25 MiB) Downloaded 1144 times
I really am not sure that i even receive CAN traffic as i now investigated charger and DCDC reporting. There is no DC voltage report even though i specificaly use it to regulate charger loop.
Of course if there is no report charger is stuck in else part of the loop. Anyone has any idea what would be the case?
EDIT: I had to reconfigure CAN receive mailboxes. Now i am getting correct data back.
My Outlander gearbox developed a leak it seems. Every day i find a small drop under the car now. When i investigated lower end of the gearbox underneath the driveshaft level on the LH side is greasy all the time. As i wiped it dry and cleaned the residue it seems it leaks from LH driveshaft opening.
I must have damaged the lip seal there. I need to replace it. Does anyone have rear GBX dissassembly procedure and maybe parts catalog?
I cant seem to access the rus site where i got most of my info about Outlander up till now.
tnx
tnx
sorry but i weighed in the ali cases etc that housed the rear diff.arber333 wrote: ↑Sun May 19, 2024 6:18 pm My Outlander gearbox developed a leak it seems. Every day i find a small drop under the car now. When i investigated lower end of the gearbox underneath the driveshaft level on the LH side is greasy all the time. As i wiped it dry and cleaned the residue it seems it leaks from LH driveshaft opening.
tnx
E46 touring
TnxBigpie wrote: ↑Mon May 20, 2024 5:43 am http://mmc-manuals.ru/Mitsubishi_Outlan ... ce_Manuals this site?
I managed to go there via VPN
EDIT: MR597852 or 3515A056 seems to be genuine P/N for Mitsu PHEV rear gbx oil seal
- Has thanked: 43 times
- Been thanked: 10 times
I ordered seals for spare Payen NJ452. Looks the same, dimensions seems to match, not needed to replace yet.
