[DRIVING] BMW Touring + phev motor & inverter
0tik
Has thanked: 15 times
Been thanked: 10 times
Re: [DRIVING] BMW Touring + prius + phev
Post by 0tik »
FFMan wrote: Tue Jan 24, 2023 10:30 am , but consensus on here seemed to be Prius motor alone would be under-powered. I wasn't sorry about that, as it is huge and weighs a ton.
Can you elaborate on that please? I wanted to try this but theres not much info on that. Wiki says mg1 and mg2 are rated for 45kw. That gives 90kw. Should be comparable to outlander rear motor.
Romale
Has thanked: 310 times
Been thanked: 81 times
Post by Romale »
0tik wrote: Sat Jan 06, 2024 1:33 pm Wiki says mg1 and mg2 are rated for 45kw. That gives 90kw. Should be comparable to outlander rear motor.
That's not so. The prius has mg1 = 18 kW, mg2 = 50 kW.
evil neodymium :twisted:
FFMan
Has thanked: 8 times
Been thanked: 47 times
Post by FFMan »
0tik wrote: Sat Jan 06, 2024 1:33 pm Can you elaborate on that please? I wanted to try this but theres not much info on that. Wiki says mg1 and mg2 are rated for 45kw. That gives 90kw. Should be comparable to outlander rear motor.
i can't remember all the detail, you could read my project post, i think its discussed in there. Also at the time the dual drive of mg1 and mg2 was i think untested and when i saw the outlander motor it looked easier, neater and a lot lighter.
E46 touring
BMW 9kwh & 12kwh packs
0tik
Post by 0tik »
Romale wrote: Sat Jan 06, 2024 4:43 pm That's not so. The prius has mg1 = 18 kW, mg2 = 50 kW.
I mean there are no posts from people actually benchmarking it.
FFMan
Post by FFMan »
0tik wrote: Sat Jan 06, 2024 4:55 pm I mean there are no posts from people actually benchmarking it.
i think was my issue at the time, it was was (and maybe still is) something of an unknown as a solution running both motors etc.
However if you are going down this route i have a pair of Prius inverters going for a song...
E46 touring
FFMan
Post by FFMan »
at last i found the issue with the DCDC not working. When i removed the gearbox and motor from underneath a while back, i managed to miss out the ground cable to the charger when putting it all back together as i was working blind on parts of it. No wonder the charger didn't want to charge the 12v battery but was fine with charging the main batteries.
All fixed - back on the road, bar a few outstanding issues, and must reinstate and troubleshoot the cabin heating tomorrow.
Ramping down of the regen as the car slows work really well, I have different regen levels for each gear, but next i want a short ramp up on application of pedal just to smooth out the small jolt on initial application.
E46 touring
FFMan
Post by FFMan »
All running ok, but i failed to get heater working properly at the weekend. Some water flow issue, so took all the pipe work out and will redesign the flow path this weekend.
Heater ramps up nicely but i think shuts down to protect itself after a minute or two.
I have a BMW bleed tap in the loop which helps but getting the air out i think is the issue to be cracked.
E46 touring
Has thanked: 134 times
Been thanked: 338 times
FFMan wrote: Thu Jan 18, 2024 7:41 pm Heater ramps up nicely but i think shuts down to protect itself after a minute or two.
See here maybe it can help you some
viewtopic.php?p=65916#p65916
Also very important is clean 0x285 message. While at first i used several functions with 0x285 within. It didnt work well even when timer was set at 10ms. Then i created a separate hardware timer that is repeating 0x285 at 10ms without any distraction. Now heater works full power without interruption.
Code is for teensy 4.1 but you simply research how to condition a function to a HWtimer trigger.
BMS_status is a value to signify the mode car is in at the time
// innitialize Timer for BMS heartbeat
IntervalTimer BMStimer;
//setup function
 BMStimer.begin(bmsComms, 10000);
 // function for 0x285
 void bmsComms()
    msg.id = 0x285;
    msg.len = 8;
    msg.buf[0] = 0x00;
    msg.buf[1] = 0x00;
    if (BMS_Status == 3) // charging
    msg.buf[2] = 0xB6;
    else if (BMS_Status == 5) //error state
    msg.buf[2] = 0x00;
    else
    msg.buf[2] = 0x14; // detup for drive
    msg.buf[3] = 0x39;
    msg.buf[4] = 0x91;
    msg.buf[5] = 0xFE;
    msg.buf[6] = 0x0E;
    msg.buf[7] = 0x10;
    Can2.write(msg);
FFMan
Post by FFMan »
thanks for that. I'll ensure i get some decent water flow and then see how it behaves. At the moment i get no warm air so pretty sure its a circ problem. I had some right angle pipes in from when i had the prius inverter. The Outlander inverter is a different shape and clears a bit of obstruction from the matrix entry points which means i can ditch the right angles.
Fingers crossed.
E46 touring
FFMan
Post by FFMan »
So i'm just about to declare this finished. The heating is working though could improve a bit, and today I fixed the charge leds on the type 2 socket, and took out the leds from the dash that i'd been unable to extinguish in code. Only one warning light remains but it has a purpose as a handbrake reminder so i'll try and turn it off in code with a bit more work.
Beginning to wonder if the E46 is harder than a later e90. My son just bought an e90 dash to hook up to the computer driving sim, and it appears to be all can, none of the k-bus and half analogue stuff of the 46. Watching the bigpie BMW with interest as it might be my next conversion.
E46 touring
FFMan wrote: Sun Jan 28, 2024 6:11 pm So i'm just about to declare this finished.
Photos!!! :twisted:
FFMan
Re: [DRIVING] BMW Touring + phev
Post by FFMan »
Photos to follow soon.
Just a quick update, at the weekend i tapped into the cabin fan wiring so via a relay i can power it using pwn externally. This means i can fire-up the heater on a timer or remotely. In theory if the charger has been set to maintain a voltage, that will then kick in so i don't deplete the batteries with the pre-heating. Will test that over the next few days.
Only 5 packs of the front 6 are reporting in. Seems like a recurring issue, suspect a poor connection somewhere even though the oem connectors locate really well. Will need to investigate but the front pack has to come out which is a pain but doable in an hour.
Next planned is a ramp in to regen, say over 1 sec to reduce the jolt at high regen levels. Also thinking of a 2 stage regen, the first stage at the moment is triggered by an extra brake light switch and activates on the free play of the pedal. I am thinking if the driver presses harder to activate the mechanical brakes this could induce a higher level of regen as well as the brakes. I am thinking regen reclaims a reasonable amount as driving round my way is often accelerate to 50, then come to a stop and lights or roundabout.
E46 touring
FFMan
Post by FFMan »
Short update on this project. The front pack BMS has a few issues. One module is lying about the value of a couple of cells, and pretty sure another module is overstating the voltage a tad as i manually checked and balanced them all. Have been looking at DIYBMS as an alternative as BMW modules are hard to come by.
In other news, the original coupler stripped. I knew it was wearing after the last gearbox removal, so prepped the replacement thinking it would be a job for the easter break. It didn't last that long. Let the wife down a mile from home, got towed back by a mate. Hoping the new couple will be a bit more forgiving, plus the latest VCU ramps up and down the regen more sympathetically, so it kinder on the drive train.
I'm guessing there must be some mis-alignment though got to say it isn't obvious.
I think MK3 coupler will be a star based coupler.
E46 touring
Ev8
Has thanked: 43 times
Been thanked: 163 times
Post by Ev8 »
Wow has that stripped the output shaft on the motor?
FFMan
Post by FFMan »
Ev8 wrote: Mon Mar 18, 2024 9:44 pm Wow has that stripped the output shaft on the motor?
yep - in about 2k miles
E46 touring
Ev8
Post by Ev8 »
Wow any sign it was doing this was it noisy from the start? Makes me wonder what mine is doing 3k plus miles later
FFMan
Post by FFMan »
no noise from the start, but it was a bit clunky as i didn't have the regen ramp up and down sorted.
according to my local gearbox guy, solid couplers can have issues, and on Land Rovers, the coupling has a life of about 50k miles
E46 touring
FFMan
Post by FFMan »
Repurposed the rev counter to be eco gauge, an idea shamelessly copied from my mates Mercedes Evan.
Rev counter seemed a bit pointless and this works nicely.
E46 touring
FFMan
Re: [DRIVING] BMW Touring + phev motor & inverter
Post by FFMan »
Touch wood but it is running well.
Managed to sort out the front BMS and balance the pack, and the new coupler is doing its thing. It's a daily driver for me or the wife as an overnight charge is 3p/mile - well happy at the moment.
E46 touring
FFMan
Post by FFMan »
I knew i would jinx it by saying how well it was going.
Coupler gave way without warning on the way to take nipper for an exam. This time it has stripped the splines on the gearbox end of the coupler. There do seem to be two versions of the clutch driven plate around. The one i used for this has quite a thin wall couple with 6 legs to fix it to the 'asbestos' liner carrier. Some are much chunkier and deeper.
So plan c is rebuild using a star coupler. Although alignment looks spot on North-South and only 1.5mm out East-West (taken up by movement in the layshaft) the star coupler should make for a happier fitting.
Parts ordered, will take a few days to machine and weld up, hopefully back on the road in a week or so.
E46 touring
