[WIP] 1974 Otis with GS450h
dombutler
Has thanked: 4 times
Post by dombutler »
well i've been lurking on here a while and I thought I would share what i'm attempting to build.
I have a stripped out Otis, the previous owner thought it was a good idea to make a custom full length gullwing doors, so he cut out the center section and junked it!
So far I have bought a gs450h transmission and inverter, the project has stalled for a couple of months mostly because I've been having trouble finding the wiring from the tranmission to the inverter (the black and grey plugs).
I plan to use a zombieverter, unsure of what battery and charger at this point.
I'm going to collect all the parts and make sure it is working before installing the transmission. This may take a while as I have 2 sons in college and trying to buy a house to get out of the ridiculous rent Im currently paying!
Thanks,
Dom
snelly
Been thanked: 12 times
Re: [WIP] 1974 Otis with GS450h
Post by snelly »
this forum is great for info
https://vintage-vans.forumotion.com/forum
Has thanked: 635 times
Been thanked: 1611 times
welcome to the GS450h Club, best of luck on your build, take tons of pics and shoot lots of video
dombutler
Post by dombutler »
So my search for some oem resolver wires still draws a blank. I've messaging anyone who is parting out a Gs450h, trying to find the cable Image
They all say no!
So the last knucklehead I contacted on ebay says yet again no he doesn't have that cable, also the same knucklehead has Toyota 90980-12520 resolver connectors with very short wires for $30 each!
Is there a definite list of main loom part numbers that fit the inverter? (because there are many) And are the Toyota 90980-12520 resolver connectors on Aliexpress any good?
On another note, I bought a 24kw battery pack with 72% soh not great, not terrible!:
Came with a few other parts, like the whole car! May have to drive it a bit first!
Yes it was cheap and yes the project is going off track before I have even started!
Has thanked: 91 times
Been thanked: 517 times
That part of the harness is simple and easy to make up yourself, the part numbers for the connectors are on the wiki. I had to make mine. I used https://www.ebay.co.uk/itm/204017685320 for the cable. Make sure not to use solid core cable.
dombutler
Post by dombutler »
Thanks for the link, that helps a bunch!
dombutler
Post by dombutler »
I'm still working on the Otis, got the rear end stripped down, does anyone know what Dana axle this is??
I've looked and I can't find anything about it, I don't know if it's going to be strong engough for my lead foot!!
The axles are 10 spline and 1.15" thick, they have ford 4.5x5 brakes and it's quite narrow
The ratio is 5.125:1 and it has an aluminum center section
What do you think? Swap it out for an 8 inch or risk it!
