no batt volts doesn't drop much and I've set any batt min limits 50v below that
[DRIVING] BMW Z3 [FINISHED]
- andybpowell
- Has thanked: 217 times
- Been thanked: 257 times
- Has thanked: 83 times
- Been thanked: 430 times
Re: [WIP] BMW Z3
I've sent you a bin with a change from Tom, possibly fixing this limit issue. God Speed
- andybpowell
Re: [WIP] BMW Z3
well I've just eaten so I wont have to eat hospital food anytime soon if I end up there
- Has thanked: 213 times
- Been thanked: 599 times
Re: [WIP] BMW Z3
Thanks Jamie, Andy please keep to a conservatie throttle max for now, we want to see if the IDC levels off as quick now. Should theoretically not be the case so the torque will carry on for longer.
- andybpowell
Re: [WIP] BMW Z3
Too late
After these 2 runs I floored it and span the wheels half way up the road, my neighbours are so pissed
Re: [WIP] BMW Z3
Now thats more then double the current draw, and no flat point insight on the current draw. Better get the car ready for some higher speed acceleration tests.
- andybpowell
Re: [WIP] BMW Z3
I'm trying to find a new diff right now
You and Jamie are a pair of absolute legends
Re: [WIP] BMW Z3
We. Need. Video.
- andybpowell
Re: [WIP] BMW Z3
sounds perfect, that was only 30% throttle too?
- andybpowell
Re: [WIP] BMW Z3
In all seriousness I really need to change the diff before it disintegrates, it sounds bad
- andybpowell
Re: [WIP] BMW Z3
the damn thing just took of like a bat out of hell I can't wait to do some real testing
Re: [WIP] BMW Z3
Be great if you could get the car sorted now you know she is dangerous. Then you can do on the move acceleration tests as those are more interesting from a performance point of view.andybpowell wrote: ↑Wed Feb 28, 2024 2:04 pm the damn thing just took of like a bat out of hell I can't wait to do some real testingthat was a real shove in the back
Re: [WIP] BMW Z3
Give it a send off with a bang?andybpowell wrote: ↑Wed Feb 28, 2024 2:03 pm In all seriousness I really need to change the diff before it disintegrates, it sounds bad![]()
- andybpowell
Re: [WIP] BMW Z3
That would be foolish as I'd have to get it home from wherever it decided to die I'll leave that sort of thing to someone silly enough to get trapped under his own bonnet
Re: [WIP] BMW Z3
I'm not sure that I do
- andybpowell
Re: [WIP] BMW Z3
having major hassle trying to get a diff with a better ratio, current is 3.45 best straight swap I can get is a 3.38 not a massive improvment but I want to get on as my mot is due in 6 weeks so I'm probably going to do it anyway
- crasbe
- Has thanked: 49 times
- Been thanked: 150 times
Re: [WIP] BMW Z3
The internet says that the diff is the same as in the E36 compact, which should be available (somewhat) plentiful. At least compared to Z3 differentials.
The compact had 3.07 and 3.23 in the 323ti and 323tiA (which stands for Automatic I guess?): http://www.e36racing.de/differenzial.php
- andybpowell
Re: [WIP] BMW Z3
they both used the med case 188 diffcrasbe wrote: ↑Thu Feb 29, 2024 3:30 pm The internet says that the diff is the same as in the E36 compact, which should be available (somewhat) plentiful. At least compared to Z3 differentials.
- Has thanked: 221 times
- Been thanked: 95 times
Re: [WIP] BMW Z3
Many thanks Guys for all this info. Is so good to see this active experiment in action. These Transmission seem to have lots of potential, on paper before, but this is realizm. Well done..
Am still seeking a 300H inverter, as my attempts with the Prius zvw30 inverter could be needing this solution..
- andybpowell
Re: [WIP] BMW Z3
My new diff is on it's way so should be able to get on soon still have to sort out the bms and charging but the weather isn't being very cooperative but I'm hoping to have all of those working and the diff in by the end of the week
- andybpowell
Re: [WIP] BMW Z3
now my diff is on the way I'm really tempted to order a lsd for it in fact I'm on the Matt Lewis racing site with it in the basket right now trying to be sensible and really struggling because I really really want it
- andybpowell
Re: [WIP] BMW Z3
wow just realised this swap from leaf to lexus has taken 5 months so far, where did that go ?
Re: [WIP] BMW Z3
Time flies like an arrow, Fruit flies like a banana.andybpowell wrote: ↑Sun Mar 03, 2024 5:26 pm wow just realised this swap from leaf to lexus has taken 5 months so far, where did that go ?
You are making good progress, well done .
- andybpowell
Re: [WIP] BMW Z3
New Diff has arrived and I havent even unboxed it yet as wouldn't you know it, it's pissing down outside
