Driving with canbus
- Been thanked: 3 times
Driving with canbus
Can someone give an example of how I start the inverter via canbus, or switch the direction D N R, would like to install a nextion display, which I use to control the whole thing??
- Has thanked: 380 times
- Been thanked: 1564 times
Re: Driving with canbus
You need to read and understand this https://openinverter.org/wiki/CAN_communication
Start signal starts, forward/reverse selects direction
This no longer works starting v5.32.R! See above!
So it no longer works that you can start the drive direction or the inverter via canbus???
Yes it does. Read again
- Bratitude
- Has thanked: 176 times
- Been thanked: 369 times
Now with throttle pre defined,
Is controlling an inverter board via a zombieverter over can as simple as setting control to can and that’s it?
I'm guessing by now someone has implemented it on the Zombie side. On the inverter side no mapping is needed, only can speed needs to match
