Accelerator pedal dead zone
Re: Accelerator pedal dead zone
I have finally merged the last pull request but something looks not right:
potnom runs in steps of 1 above 0 and even steps of 5 in regen
mane2
Has thanked: 50 times
Been thanked: 61 times
Post by mane2 »
That looks completely wrong. Also the acceleration looks off, as it should be linear. Are you sure it's the right code?
How do you test? Can I replicate that test somehow?
What maxregentravelhz have you set? How about what rotor hz are you passing? If rotor hz is 0, it calcThrottle will return the same value as potnom.
I tested passing 0,0 -> 50,0 and back from 50,0 to 0,0 with increment of 0,25 and results are not in steps of 1 or anything like what you're seeing there. Here's a sample of what calcThrottle() returns (going up to 50% and then down, using params: regentravel=30.0, regenrampstr=19.0 brkmax=-60.0 brknompedal=-60.0, maxregentravelhz = 200)
throttle 49.000000 potnom 49.000000
throttle 49.250000 potnom 49.250000
throttle 49.500000 potnom 49.500000
throttle 49.750000 potnom 49.750000
throttle 50.000000 potnom 50.000000
throttle 48.750000 potnom 48.750000
throttle 48.500000 potnom 48.500000
throttle 48.250000 potnom 48.068237
throttle 48.000000 potnom 47.466305
throttle 47.750000 potnom 46.708073
throttle 47.500000 potnom 45.810776
throttle 47.250000 potnom 44.796227
throttle 47.000000 potnom 43.691948
throttle 46.750000 potnom 42.532146
throttle 46.500000 potnom 41.358173
I've been running with this code in my car past weekend and it has worked flawlessly. Though, I can't see plot in that precision from the webui. (especially when I barely get signal when running the car :)) But when testing the calcThrottle function (using test_sine), it works like it should - with decimals too.
I used this code: https://github.com/jsphuebner/stm32-sine/pull/42
maxregentravelhz=90 (the default) . I used a signal generator with 0.1 Hz saw tooth 0-2V
Will test more later
I have stripped the code back down to the basics and it is also quite well drivable. Of course I never had a chance to test yours so can't compare
https://github.com/jsphuebner/stm32-sin ... f2268f195e
It's a simple linear curve, more speed more regentravel until maxregentravelhz is hit
mane2
Post by mane2 »
Ok. That looks simple and easy to understand. Good to get rid of that dead zone with the official firmware too :). Hopefully I made it bit easier for you :)
I agree that my code was bit difficult to read and maybe not as simple as I would liked it to be, but it works very nicely. Thought, just found out that there was a small bug related to increasing the regentravel - it never reached max. Just fixed that to my fork of stm32-sine.
Did you find out what was causing those weird steps in your graph?
muehlpower
Been thanked: 188 times
Post by muehlpower »
I really like the new “maxregentravelhz” parameter. Unlike mane2, I don’t want “one-pedal driving” but rather behavior similar to a combustion engine. To achieve this, I would set a moderate regen for “off-throttle” and handle the rest with a potentiometer on the brake pedal. I’d like to choose the redundant variant for the gas pedal (potmode=1). Does it make sense to query the brake pedal position externally and continuously adjust the value for “off-throttle regeneration” via CAN? For example, 20% when the brake is not applied and a brake-pedal-dependent increase up to 100%. This would also have the advantage that I could reduce the value to 0% in the event of excessive braking on the rear axle (overbraking).
