Someone doesnt like us very much
- Has thanked: 12 times
- Been thanked: 350 times
- Has thanked: 380 times
- Been thanked: 1571 times
Re: Someone doesnt like us very much
Does it really... Most of the efficiency would be in the hardware design of the motor, which we keep. Some can be gained in the power electronics section, which we keep.I don't consider this full control of the units, since it's just an ugly replacement that loses all of the efficiency inherit in the system from Tesla's R&D
If you totally screw up the software or parameters you can loose some efficiency by running too much or too little slip. Yes that is a possible weakness.
Still, hats off for what the guy has achieved. I wonder if it's open knowledge though.
Actually he has published a quite comprehensive document
It's on Lees google drive: https://drive.google.com/drive/folders/ ... ZCk_yWTE7e
So much for lost efficiency :
https://www.independent.ie/life/motorin ... 04361.html
Not bad for Another Homebrew AC Controller
Wow, this is actually based on Maguire/Huebner tech? Whats the story?
- Kevin Sharpe
- Been thanked: 8 times
Thanks Kevin, seems like replacing the Tesla logic board is a really bad idea
