rstevens81 wrote: ↑Tue Dec 13, 2022 8:36 am
based on the detailed guide (as posted by tom):
https://assets.publishing.service.gov.u ... hicles.pdf ...
There is no requirement for abs...
power steering looks very similar
I would not expect it to be that hard for Bitsilly to get an IVA for his mini particularly as the car was in production till 99 (im not suggesting he would pass first time), but there is nothing that would shout i'm more dangerous than a home built Haynes 7.
most stuff isn't needed for an IVA i.e airbags etc, you have to remember that all an IVA is a super MOT for kit cars, there are rules about external fittings like wing mirrors (basically so you cant clip someone and drag them along etc) so you might have to change them for the test but nothing that would stop an old car from being put back on the road, the duel circuit brake system might mean you need to re plumb your brakes with a valve that triggers when 1 one starts to leak, but all in all quite minor.
the hardest part is the HV battery although i believe janosch has done this a few times with his taxis (quoted below)
To re iterate what i have said previously
1.
don't drill any holes if you can
2. if you cant its an IVA but that not the end of the world you'll probably be out of pocket by an extra £1500-£2500.
Hi guys
As I have removed the cubby box from under the boot of my 2004 Freelander (only held in by a few spot welds) to make space for a battery box I suspect I may need to get an IVA.
I had thought it would be around £200 to have it tested so wasn't too concerned but if it was to be £1500 to £2500 then I'd be very concerned.
Thankfully I have only been working on a test mule car and have yet to transfer everything to the real car so I can change anything I need to.
I will probably make changes to the battery supports under the bonnet to avoid drilling the frame rails as drilling holes is a theme here.
The biggest unknown for me is I am in Northern Ireland so I everything could be easier or harder for me and I won't know until I try.
I'm going to make a phone call in a few weeks when my work calms down so will update then.
