WANTED: Tesla model 3 rear motor case
steveknox
Has thanked: 16 times
Been thanked: 14 times
Post by steveknox »
Hi All
I have a tesla model 3 motor with a broken motor mount, the non-removable one on the inverter/motor side connected to the case. Does anyone have a broken / damaged rear model 3 motor from which I could buy the case?
See below for what I need.
Thanks!
Mazda RX-8
GS450h Running Gear
Outlander Charger
Renault Kangoo 36kwh pack
TinkerTan
Re: WANTED: Tesla model 3 rear motor case
Post by TinkerTan »
I have an intact M3 SDU I could pull that from. Are you willing to ship me your broken one, with the bushing & broken aluminum piece? What are you looking to spend?
steveknox
Post by steveknox »
Hi, thanks for the reply!
yea I'm willing to swap the parts but I don't have the missing bushing or broken aluminium piece unfortunately.
The removeable mount on the other side of the motor is the same diameter so my backup plan was to buy
one of those on ebay (~50gbp) and weld on the mount from there.
In terms of expenditure, i'm looking to spend maybe a few hundred GBP at most, but resources are limited
Cheers
Steve
Mazda RX-8
GS450h Running Gear
Outlander Charger
TinkerTan
Post by TinkerTan »
I'm not sure it will be viable, especially as I would prefer to have a repairable housing.
My lowest DHL quote is ~$350 (USD)
steveknox
Post by steveknox »
Yes I don't think that's realistic. Thanks a lot for the offer though.
Mazda RX-8
GS450h Running Gear
Outlander Charger
muehlpower
Has thanked: 14 times
Been thanked: 141 times
Post by muehlpower »
Don't you have anyone nearby who can weld aluminum?
steveknox
Post by steveknox »
Yep, but I'm worried about the strength of any patch repairs. Perhaps that's unfounded? Also I don't have the missing pieces so the miunt would need fabricating or transplanting from somewhere else.
Mazda RX-8
GS450h Running Gear
Outlander Charger
TinkerTan
Post by TinkerTan »
I also realized the shipping would be significantly more. I forgot that the stator is affixed inside that housing, so the weight I provided is probably 10-20% of actual.
That's a bummer.
I do think it should be fairly easy to accomplish or surpass OEM strength of that mount using Aluminum MIG. Aluminum MIG (with a spoolgun) is an easy way to deposit a lot of metal quickly.
In fact on this drive unit, one of the other mounts is broken. That's how I plan to repair it when it comes time to use it.
