Building blocks on hand:
- 2003 Dodge Dakota 4x4
2017 Leaf "stack" and other components
2021 Leaf 110kW stack and axles
ZombieVerter VCU
- Battery. There's a Chevrolet Bolt battery locally for a fair (?) price ($3300). Thoughts?
Leaf Gen2 control board
The ZombieVerter VCU will control the charger and DC-DC converter. The Dodge instruments appear to be CAN controlled so hopefully I can work out a speedometer and other gauges. This will be a lot to learn as CAN is not common in my industry and I have no direct experience.
Phase 1 of the build will culminate in an operational front-wheel-drive pickup with power brakes and power steering.
Later parts of the project include CHAdeMO charging and integrating the Leaf heater core and AC compressor into the Dodge HVAC system.
Phase 2 will remove the pickup box and rear axle to be replaced with a drop-side flatbed, De Dion rear suspension and a second Leaf motor.
The truck will be lowered a bit for handling and aerodynamic improvements made to increase range.
Cheers!
Josh
