LEM CAB300 C/SP2 Current Sensor
Hi
I have a LEM CAB300 C/SP2 Current sensor, that is making a hi pitch noise about 18khz, running of bench PSU
the can message are OK, has anyone tested one before and hared them?
m.art.y
- Has thanked: 38 times
- Been thanked: 37 times
- Has thanked: 330 times
- Been thanked: 847 times
Re: LEM CAB300 C/SP2 Current Sensor
Its not hard, info is in the datasheet.
Mind posting what your recieved CAN looks like? Where did you get the sensor from?
it was from ebay looking at the can signal its just ____-______-______-_____- so the timing interval is 19khz so looks like the sensor integral dc dc switching noise i can hear.
conclusion is the senser is duff
thanks for every ones help
- larsrengersen
- Has thanked: 16 times
- Been thanked: 36 times
Think there are some fake China copies around. I made that mistake one day when they were hard to source. Threw them away and now only use and stock original ones bought from LEM directly myself.
It was from a used car braker not in antistatic rapping, have you any in stock?
m.art.y
Has anyone tried to configure those for a different CAN speed? It says in the datasheet they are configurable. Wonder how? I would need 125 kbps speed
- larsrengersen
- larsrengersen
The CAB300 is fixed at 500 kbps. Some CAB500's can be reconfigured.
m.art.y
Does anybody know if orientation of the CAB300 matter? It can be mounted with the front side with LEM logo facing the battery and with the back side facing the battery. I mean will current reading be positive or negative or it won't have any difference?
From the datasheet
Installation requirements in this datasheet for the CAB sensor range.
https://www.lem.com/sites/default/files ... eet_v1.pdf
m.art.y
Hi, sorry for non technical person is the positive current when it is drawn from the battery through the negative busbar?tom91 wrote: ↑Sun Sep 08, 2024 5:56 pm image.png
From the datasheet
hi thanks I now got a new IVT-S-300-U3-I-CAN1-12/24 instead, by the way could not get on you website it was block my endlarsrengersen wrote: ↑Sat Sep 07, 2024 5:38 pm Yes https://www.evcreate.com/shop/charging/ ... nt-sensor/
- Has thanked: 166 times
- Been thanked: 411 times
I noticed CAB300 pdf is not available anymore. I think there is a lot of those stil available from Outlander cars...
I am posting a file for sp2 version here for future...
cab_300-c_sp2.pdf- (1.1 MiB) Downloaded 537 times
I found CAB300 connector, which is CAB500 connector as well:
4P Female P/N 1473672-1
Pins Female Crimp 1123343-1
m.art.y
Anybody had CAB300 sensor die on them? They are either very sensitive when you accidentally mix CAN wires or are just prone to failure as two died on me in a short time. It still sends it's message but only savvycan can read it as the voltage between CAN wires is only 300mv. You connect it to the bus in the car and bus goes dead.
