Help with a Simple (Hopefully) CCS Charge Curve? Topic is solved
P.S.Mangelsdorf
Has thanked: 235 times
Been thanked: 278 times
Post by P.S.Mangelsdorf »
Since FOCCCI requires something else to tell it what current to request from the charge station, and my BMS is not set up to do that, I'm working on a simple board to take the battery voltage (in my case from the ISA shunt, but from the BMS could work too) and then output a current request based on these and basic ramping (reduce current at low voltage, ramp down to full charge). Later, I hope to add controls for temperature, but for right now I'm focused on ramping based on SOC.
I'm basing it off of this board: https://www.longan-labs.cc/1030018.html
Which uses this library: https://github.com/Longan-Labs/Arduino_ ... ree/master
The code block below is the best effort of myself and ChatGPT. Can anyone check my work? I'm really out of my depth here:
#include <SPI.h>
#include <mcp_canbus.h>
#define SPI_CS_PIN  17
MCP_CAN CAN(SPI_CS_PIN); // Set CS pin
unsigned long lastSendTime = 0;
const unsigned long sendInterval = 250; // 0.25 seconds
const int maxChargePower = 50000; // 50kW in watts
const int targetVoltage = 400; // Target voltage in volts
const int maxVoltage = 398; // Maximum voltage in volts
const int minVoltage = 288; // Minimum voltage in volts
void setup() {
  SPI.begin();
  if (CAN.begin(CAN_500KBPS) == CAN_OK) {
    Serial.begin(9600);
    Serial.println("CAN init ok!");
  } else {
    Serial.println("CAN init fail");
    while (1);
void loop() {
  if (millis() - lastSendTime >= sendInterval) {
    lastSendTime = millis();
    // Receive voltage message
    if (CAN_MSGAVAIL == CAN.checkReceive()) {
      unsigned char len = 0;
      unsigned char buf[8];
      CAN.readMsgBuf(&len, buf);
      unsigned long canId = CAN.getCanId();
      if (canId == 0x522) {
        int voltage = (buf[2] << 8) | buf[3]; // Voltage in millivolts
        voltage /= 1000; // Convert to volts
        // Calculate charge current request
        int chargeCurrent = calculateChargeCurrent(voltage);
        // Send charge current request
        sendChargeCurrentRequest(chargeCurrent);
        // Send target voltage
        sendTargetVoltage(targetVoltage);
        // Calculate and send SOC
        int soc = calculateSOC(voltage);
        sendSOC(soc);
int calculateChargeCurrent(int voltage) {
  int chargePower;
  if (voltage < 300) {
    chargePower = 20000; // 20kW
  } else if (voltage < 320) {
    chargePower = 35000; // 35kW
  } else if (voltage < 376) {
    chargePower = maxChargePower; // 50kW
  } else if (voltage < maxVoltage) {
    chargePower = maxChargePower * (maxVoltage - voltage) / (maxVoltage - 376);
  } else {
    chargePower = 0;
  return chargePower / voltage; // Current in amps
void sendChargeCurrentRequest(int chargeCurrent) {
  unsigned char data[8] = {0};
  data[0] = chargeCurrent & 0xFF;
  data[1] = (chargeCurrent >> 8) & 0xFF;
  CAN.sendMsgBuf(0x300, 0, 8, data);
void sendTargetVoltage(int targetVoltage) {
  data[0] = targetVoltage & 0xFF;
  data[1] = (targetVoltage >> 8) & 0xFF;
  CAN.sendMsgBuf(0x301, 0, 8, data);
int calculateSOC(int voltage) {
  return (voltage - minVoltage) * 100 / (maxVoltage - minVoltage);
void sendSOC(int soc) {
  data[0] = soc & 0xFF;
  data[1] = (soc >> 8) & 0xFF;
Has thanked: 378 times
Been thanked: 1559 times
Re: Help with a Simple (Hopefully) CCS Charge Curve?
Here my 3 step version https://github.com/jsphuebner/stm32-car ... s.cpp#L121
It is based on the highest individual cell voltage though not total pack
P.S.Mangelsdorf
johu wrote: Sun Sep 08, 2024 8:21 am Here my 3 step version https://github.com/jsphuebner/stm32-car ... s.cpp#L121
Thanks, I'm going this much cruder route given my time constraints and what I have on hand. Eventually, my very ambitious plan is to have a Zombie-esque STM32 board that just handles battery stuff - talks to the OEM BMS, charger, DC-DC, FOCCCI. But right now I just need CCS to work, and unfortunately my CANDue based CAN interface has crapped out, so I can't easily see what's getting sent. I have stuff on the way to hopefully address that, but not arriving until Wednesday.
P.S.Mangelsdorf
Just to update in case it helps anyone else: I did eventually get this code working, on the 4th revision. Using some of the examples from Longan Labs, I figured out a better way to structure/handle the CAN messages. It took a bit of common sense and basic code knowledge to catch the issues with the ChatGPT proposed code. Namely, ChatGPT kept wanting to structure it so that the outgoing message timer was only triggered after a new battery voltage message came it.
My code is below, in case anyone wants to use it. It is intended for a Longan Labs CANBed RP2040. Please note, there are a few things hard coded you'll likely want to adjust, including max/min voltages, max power (in my case its set to 50kW), and the voltages at which ramping occurs.
#include <Arduino.h>
#include <SPI.h>
#define SPI_CS_PIN  9
#define CAN_500KBPS         16
const int targetVoltage = 398; // Target voltage in volts
int voltage = 0;
void setup() {
  // Initialize serial communication
  Serial.begin(9600);
  while (CAN_OK != CAN.begin(CAN_500KBPS)) {    // init can bus : baudrate = 500k
    Serial.println("CAN BUS FAIL!");
    delay(100);
  Serial.println("CAN BUS OK!");
  // Set mask to accept all bits
  CAN.init_Mask(0, 0, 0x7FF);
  CAN.init_Mask(1, 0, 0x7FF);
  // Set filter for specific ID 0x522
  CAN.init_Filt(0, 0, 0x522); // Filter 0 for ID 0x522
void loop() {
    // Declare required variables
    long unsigned int rxId;
    unsigned char rxBuf[8];
    int batteryVoltage = 0;
    // Check for new CAN messages
    if (CAN.checkReceive() == CAN_MSGAVAIL) { // Check if data is available
        CAN.readMsgBufID(&rxId, &len, rxBuf);
        if (rxId == 0x522) { // Process only messages with ID 0x522
            // Extract battery voltage from CAN message
            long batteryVoltage = (long)((rxBuf[5] << 24) | (rxBuf[4] << 16) | (rxBuf[3] << 8) | rxBuf[2]); // Voltage in millivolts
            voltage = batteryVoltage / 1000; // Convert to volts and store
        sendSOC(soc);
  int chargePower;
  } else {
    chargePower = 0;
  CAN.sendMsgBuf(0x305, 0, 8, data); // Changed message ID to 0x305
uhi22
Has thanked: 206 times
Been thanked: 617 times
Post by uhi22 »
Would it help if we integrate such quick and dirty BMS functionality into Foccci? (Not as a recommended approach, but just to simplify the life for situations where a real BMS is not yet funished)
P.S.Mangelsdorf
uhi22 wrote: Sun Sep 29, 2024 9:12 pm Would it help if we integrate such quick and dirty BMS functionality into Foccci? (Not as a recommended approach, but just to simplify the life for situations where a real BMS is not yet funished)
I'm not sure. I do like that the old CHAdeMO control board could handle everything itself, but I also see the argument for safety and simplicity of wanting some other part of the car to provide the current request. I don't know enough about other BMS's to know if they are capable of sending the requests FOCCCI wants, or if that will require customization/separate boards as I have done here.
This code is just my first stab at it - I do eventually want to add temperature derating and other functionality.
Stepping way back, I think it would be more useful long term to develop a Zombie-type master control board for handling battery functions (communicate with OEM BMS, control chargers, control DC-DC, talk to FOCCCI, etc) and leave FOCCCI for just CCS comms and Zombie for just drivetrain control, but I understand that a) that is personal preference and b) I should improve my C++ skills and do that myself rather than hoping/suggesting someone else do it. It's on my long term project list.
Has thanked: 207 times
Been thanked: 571 times
P.S.Mangelsdorf wrote: Mon Sep 30, 2024 3:46 pm Zombie-type master control board for handling battery functions (communicate with OEM BMS, control chargers, control DC-DC, talk to FOCCCI, etc
Zombie is doing this already, upcoming release will make Foccci supported and a few BMS options also.
uhi22
Post by uhi22 »
Okay, this sounds like the "dirty BMS" inside Foccci is not really helping. Because:
- For cars which have the Zombie, this can calculate the charge current and provide it to Foccci.
- For cars where the BMS itself provides the charge current, Foccci can take this.
- For the Shocking Chevy, Paul has the CANBed RP2040 with a basic charge curve and can improve this step by step, which is a good learing experience.
- Maybe there are more cases, which we can discuss in detail as soon as they occur.
P.S.Mangelsdorf
tom91 wrote: Mon Sep 30, 2024 5:31 pm Zombie is doing this already, upcoming release will make Foccci supported and a few BMS options also.
I knew Zombie was handling chargers and DCDC, did not know it would be supporting OEM BMSs.
My line of thinking was a Zombie based board that in some ways took the place of SimpBMS for those of us in North America, and handled just battery functions. Personally, I'd like battery functions to be handled separately from drivetrain, but as noted I know that's a personal preference.
uhi22 wrote: Mon Sep 30, 2024 6:55 pm - For cars where the BMS itself provides the charge current, Foccci can take this.
I do wonder how many BMSs currently can do this, but I agree it is the preferrable option.
uhi22 wrote: Mon Sep 30, 2024 6:55 pm Paul has the CANBed RP2040 with a basic charge curve and can improve this step by step, which is a good learing experience.
It's certainly a learning experience!
I also just want to add my thanks to both of you for the work you've done on BMSs and FOCCCI respectively, it is a huge service to the community and I really respect your work and knowledge. I don't think we all thank you enough for your efforts, so once again, thank you.
P.S.Mangelsdorf wrote: Tue Oct 01, 2024 1:33 pm My line of thinking was a Zombie based board that in some ways took the place of SimpBMS for those of us in North America, and handled just battery functions. Personally, I'd like battery functions to be handled separately from drivetrain, but as noted I know that's a personal preference.
Zombie does not handle batteries it handles BMS information, so it would function with/along side a SimpBMS/OEM BMS/EVS-BMS
The BMS MUST define the charge curve as it has all the info to hand. Believe Thunderstruck BMS was forced to do this to handle the Fellten CCS kit.
At the very least it must handle battery limits and be capable of stopping charging.
Aragorn
Has thanked: 6 times
Been thanked: 65 times
Post by Aragorn »
Why are you limiting charge current so much at lower SOC?
Dont most EV's see thier highest charging powers at those lowest points?
uhi22
Post by uhi22 »
I think the idea is: At low SOC there is an increased inner resistance. Pushing the full current would produce heat, which speeds up the aging. But depending on the cell type this seems to be not always necessary, my Ioniq takes 175A constant from 0% to 78% at normal temperatures.
P.S.Mangelsdorf
Aragorn wrote: Tue Oct 01, 2024 3:18 pm Why are you limiting charge current so much at lower SOC?
uhi22 wrote: Tue Oct 01, 2024 7:19 pm I think the idea is: At low SOC there is an increased inner resistance. Pushing the full current would produce heat, which speeds up the aging. But depending on the cell type this seems to be not always necessary, my Ioniq takes 175A constant from 0% to 78% at normal temperatures.
I had mostly read that they had highest power at the middle of the charge curve.
From the DOE testing of these batteries, they can take more power and abuse than I am giving them, but I do want to be careful and not add to the degradation. I'm already doing the inadvisable heavy depletion and charge to 100% repeatedly on these road trips, so I want to be as gentle as I can otherwise.
I definitely will be making adjustments to this curve over time as I learn more.
Aragorn
Post by Aragorn »
Take a look at the Fastned charging curves for various EV's, they all go hard right from the low end then taper off as the SOC increases.
Perhaps be careful below 10%, especially if you've run it really low, but from 10% upwards you should be able to run 50kw
An example:
muehlpower
Has thanked: 14 times
Been thanked: 141 times
Post by muehlpower »
I found this charging curve from Texas Instruments. It shows that up to 3V cell voltage is only charged with 10%, then full power until the maximum cell voltage of 4.1V is reached. This is maintained until the current has dropped to 10%. This is the end of charging. This behavior corresponds to what I have seen in OEM cars, but there is always no indication of the cell voltage, which is required for control.
Aragorn
Post by Aragorn »
Yeah, i imagine most OEM cars wouldnt let the battery get below 3v per cell anyway... Hence they all go very quickly to full current.
P.S.Mangelsdorf
muehlpower wrote: Thu Oct 03, 2024 2:08 pm I found this charging curve from Texas Instruments. It shows that up to 3V cell voltage is only charged with 10%, then full power until the maximum cell voltage of 4.1V is reached. This is maintained until the current has dropped to 10%. This is the end of charging. This behavior corresponds to what I have seen in OEM cars, but there is always no indication of the cell voltage, which is required for control.
That's interesting - so they're continuing to provide (decreasing) current after reaching full voltage?
I do know that these Volt packs' charge/discharge curve is more linear than that example, so not sure how that impacts it.
muehlpower
Actually it should be quite easy. Up to 3V 0.1C, so in my case 74000Wh/360V/10=20A, then 200A. At the same time transmit a voltage of 4.1Vx96= 393V. Then the charging station should automatically reduce the amps so as not to go above 393V. For the 3V, the cell with the lowest voltage is crucial. To transmit the maximum voltage, the cell with the highest voltage must be observed and the value corrected if necessary. There is no need to reduce the amps, just observe and stop charging at 20A.
In addition, the temperatures of the battery and the connection should be monitored and the current reduced if necessary. Battery 10°C to 45°C, connection up to max 70°C
P.S.Mangelsdorf
After doing some testing this weekend, I'm definitely going to do some tweaking to the curve. It ramps down way too early and too far. Not sure the details yet, but hoping to work on that this week and test again next weekend.
uhi22
Post by uhi22 »
Missing Pete. The charge curve would be a perfect topic for testing on a simulator...
P.S.Mangelsdorf
No update on testing this week - I had to get caught up on things around the house. Weather here in NC decided to jump straight from summer to late fall and I was behind on yard work. Maybe some opportunities this week.
Zieg
Has thanked: 155 times
Been thanked: 147 times
Post by Zieg »
So is 1c kind of a safe limit to follow, assuming temps stay down? And would that be defined as charging amps = 1 x the amp hour capacity, or charging kW = 1 x the kWh capacity?
P.S.Mangelsdorf
So I've done some tweaking, and found a few things:
The linear ramp down doesn't work great in practice, especially when I made it a steeper slope (starting later, from a higher charge power). Basically, as the voltage increases, the current request drops, and when the station backs down the power, the voltage settles slightly, causing the current request to increase, raising the voltage, causing the current request to decrease, etc. It doesn't get completely in a loop, but it does make things choppy in a disconcerting way. The stations I've tested also seem to shut off early, likely because of the aggressive ramp rate (I raised the voltage at which ramping begins and let it request more power). I haven't had my laptop with me to confirm the shut down reason (just charging while out playing with the car) and my phone doesn't like to actually switch nodes on the web interface.
My plan, which I hope to implement and test this weekend, will be to change to a stepped ramp, rather than a linear one. Will report back based on that testing, and I'll actually remember my laptop this time.
P.S.Mangelsdorf
Well I made some further updates to this curve and finally was able to test this weekend.
Changes include:
Stepped ramp down
reporting SOC in 10% intervals rather than strictly a linear interpolation
On the plus side, it seemed to work flawlessly. There is still some back and forth at the points where it drops power and the voltage settles, but much less significant than prior.
However, the power ramps down too quickly. I ended up sitting at 25kW and then 8kW for a long time, on a 100kW station. I'm going to further adjust those ramp points and ramp percentages. I'll likely make the percentages into variables, like the ramp points are, to make adjustments easier.
#include <SPI.h>
const int maxChargePower = 100000; // 100kW in watts
const int RampPoint1 = 376; //Voltage at which power reduced to 75%
const int RampPoint2 = 385; //Voltage at which power reduced to 50%
const int RampPoint3 = 390; //Voltage at which power reduced to 25%
const int RampPoint4 = 395; //Voltage at which power reduced to 10%
int voltage = 0;
void setup() {
  Serial.begin(9600);
    delay(100);
void loop() {
        sendSOC(soc);
  int chargePower;
  } else if (voltage < RampPoint1) {
  } else if (voltage < RampPoint2) {
    chargePower = maxChargePower * 0.75;
  } else if (voltage < RampPoint3) {
    chargePower = maxChargePower * 0.5;
  } else if (voltage < RampPoint4) {
    chargePower = maxChargePower * 0.25;
    chargePower = maxChargePower * 0.1;
  } else {
    chargePower = 0;
  CAN.sendMsgBuf(0x300, 0, 8, data);  //current request as CAN message 0x300
  CAN.sendMsgBuf(0x301, 0, 8, data); //Target Voltage as CAN message 0x301
  // Calculate the SOC as a percentage based on the min and max voltages
  int soc = (voltage - minVoltage) * 100 / (maxVoltage - minVoltage);
  // Round down to the nearest 10%
  soc = (soc / 10) * 10;
  // Ensure SOC is between 0 and 100
  if (soc > 100) soc = 100;
  if (soc < 0) soc = 0;
  return soc;
  CAN.sendMsgBuf(0x305, 0, 8, data); //State of Charge as CAN message 0x305
Zieg
Post by Zieg »
Hey have you made any further tweaks to this code? It looks like my BMS just commands the same current regardless of SOC, so I'm planning to implement something similar.
