Volvo EPS
medo
Volvo EPS
Post by medo »
is there a way to implement the volvo eps in the vcu ??
or is it already being worked on
https://github.com/NMSTEC/Volvo_EPS_FREE
I thought that it could be implemented speed-dependently, instead of the potentiometer, with a fine adjustment in the VCU
Has thanked: 134 times
Been thanked: 336 times
Re: Volvo EPS
crasbe
Has thanked: 47 times
Been thanked: 150 times
Re: Volvo EPS
Post by crasbe »
And there's a (beginning of a) Wiki article: https://openinverter.org/wiki/Volvo_Power_Steering_Pump
If you find some information to contribute, please add them to the wiki as well.
medo
Re: Volvo EPS
Post by medo »
Unfortunately I can't program, otherwise I would have implemented it in the zombieverter so that you have an option to select whether a Volvo EPS is installed, if so, then you should be able to select whether it is speed-dependent or whether you can set the speed manually, CAN messages are now known and there are also good examples
for example, speed-dependent, 100% - 10% = 0 km/h - 50 km/h
very nicely illustrated as can be seen here
https://www.nmstec.ca/product/psc/
https://www.youtube.com/watch?v=ns88mwGoSsA
projectgus
Has thanked: 39 times
Been thanked: 33 times
Re: Volvo EPS
Post by projectgus »
I've recently obtained a pump from a Volvo S40 and was able to find the OEM connectors (from Yasaki). Have added the OEM part numbers and a labelled connector photo to the wiki page.
medo
Re: Volvo EPS
Post by medo »
If this were implemented in the VCU, that would be perfect
