Nissan Leaf ZE1 AC compressor LIN
Has thanked: 207 times
Been thanked: 571 times
Re: Nissan Leaf ZE1 AC compressor LIN
aot93 wrote: Wed Oct 30, 2024 1:59 pm or try to log / playback to the compressor not attached to the car.
You got a LIN setup with an arduino might be worth trying.
Playing back is not possible with the USB Analyser.
aot93
Has thanked: 8 times
Been thanked: 48 times
Post by aot93 »
I don't,
But I should have the bits to make a LIN setup, just a level shifter required by the looks of it?
Marat
Been thanked: 12 times
Post by Marat »
Check CRC? ID47
Marat wrote: Sat Nov 02, 2024 8:56 pmCheck CRC? ID47
The CRC is calculated as the Avanched LIN 2.0 CRC and it checks out as correct according to my Lin capture device. But can mess around a bit with this.
Marat
Post by Marat »
dimonlipko
Has thanked: 7 times
Been thanked: 10 times
Post by dimonlipko »
I work with LIN, and have the same problem. I think your problem was wrong ID, because in LIN can be protected ID, and check CRC. I try any Arduino Lin library and some have problem with it.
Okay so you would not believe the issue. Message timing.
I reviewed logs and my code and noticed even though it is supposed to run even 100ms the loop was not being ran that fast. So adding it to a mytimer call back it now send the the LIN frames at 10Hz as per log. I believe you could theoretically run it at a slower speed, seems to try and go at 3Hz but need more testing.
Should have realised from your post too, each frame ever 100ms. (10hz)
abetanco
Has thanked: 25 times
Post by abetanco »
aot93 wrote: Wed Oct 30, 2024 2:06 pm I don't,
Hello, this post may help you if you need to send LIN with an Arduino:
viewtopic.php?t=2136
