[WIP] Porsche 924 Safari electric
mrfred
Has thanked: 4 times
Post by mrfred »
Time to share my project. I will be converting a 1979 Porsche 924.
The goal of the project besides completing the conversion is to learn how to weld, restore and have fun along the way. The car was in very poor condition when I bought it and I have no experience with welding or fabrication. So it's taking time but slowly, slowly, progress is being made.
A large part of the project involves rust repair and I will be more or less restore everything on the car including a completely new 12V system.
-- Plan --
Car: Porsche 924, raised and with offroad tires. Yes I know! Bad combination for an EV :)
Powertrain: Mitsubishi Outlander rear drive unit and inverter.
Charger: MG ZS EV(?) 3-phase charger
Battery: 35kWh VW e-Golf battery
mrfred
Re: [WIP] Porsche 924 Safari electric
Post by mrfred »
Repaint in white 2k bedliner.
Has thanked: 330 times
Been thanked: 848 times
mrfred wrote: Fri Dec 13, 2024 12:58 pm Mitsubishi Outlander rear drive unit and inverter.
What sort of performance are you expecting? This is quite a limited power drive unit which will have lower performance then the stock vehicle most likely.
mrfred
Post by mrfred »
Dashboard restoration.
mrfred
Post by mrfred »
tom91 wrote: Fri Dec 13, 2024 1:02 pm What sort of performance are you expecting? This is quite a limited power drive unit which will have lower performance then the stock vehicle most likely.
Not very high expectations. Over time, it could become a more exciting drive train but for now this is more of a learning project :)
mrfred
Post by mrfred »
As I said, the goal is to learn. I will do all the welding with TIG but a friend was nice enough to step in and weld the motor mounts. I dont trust myself just yet to do the important welds.. :)
Has thanked: 246 times
Been thanked: 469 times
nice work on making drive shaft flanges instead of custom axles!
mrfred
Post by mrfred »
Bratitude wrote: Sun Dec 15, 2024 3:31 am nice work on making drive shaft flanges instead of custom axles!
Thanx! :)
mrfred
Post by mrfred »
Engine bay and cross member touch up:
Steering rack refurbish:
iBooster, Wilwood proportioning valve and bracket install and creation:
mrfred
Post by mrfred »
Trying out zinc plating. I'm not sure if I think the style suits the car, but it's fun to experiment! :)
crasbe
Has thanked: 58 times
Been thanked: 180 times
Post by crasbe »
The results look really nice and I don't want to be that guy, but be careful when zinc plating bolts (or parts in general). They can lose a lot of their original strength due to hydrogen embrittlement.
mrfred
Post by mrfred »
crasbe wrote: Wed Dec 18, 2024 6:13 pm The results look really nice and I don't want to be that guy, but be careful when zinc plating bolts (or parts in general). They can lose a lot of their original strength due to hydrogen embrittlement.
Didnt know that. Thanx for telling me!
Has thanked: 363 times
Been thanked: 249 times
Post by jrbe »
Looks good.
You can do a post plating bake soon after to combat the hydrogen entitlement. Look up specs for what you're plating.
DVD3500
Has thanked: 90 times
Been thanked: 9 times
Post by DVD3500 »
Warning: Slightly off topic
Which is one of the reasons pumping hydrogen into natural gas lines is a huge risk as well... Furnaces are being sold as "hydrogen ready" which is the same as saying my garage is "Ferrari ready". When pipes start cracking and hydrogen starts leaking all over people will see what an idiotic use this was for hydrogen...
Rant over. :-)
