Hello,
I hope you’re doing well. I’m currently running a Nissan Leaf drivetrain (inverter, PDM, and motor) with a ZombieVerter as the VCU. I’ve attempted to access the gauges through the "Show Gauges" option in the web interface, but after being redirected to a new tab, nothing is displayed.
I would greatly appreciate any guidance or assistance you can provide to help resolve this issue.
Thank you in advance for your time and support.
ZombieVerter Show Gauges Guidance Topic is solved
- Has thanked: 83 times
- Been thanked: 430 times
Re: ZombieVerter Show Gauges Guidance
Are you using the CAN or UART based web interface?
I’m not entirely sure. I received the VCU from Damien, and it came with the web interface already configured. I simply access it by entering 192.168.4.1 in the browser. However, I suspect that I might be using CAN. Am using the new recommended Wi-Fi as shown below
Ok. So that's the usrt backed. So which version of the UI do you have? Can you post a screenshot of the homepage?
- robertwa
- Has thanked: 116 times
- Been thanked: 128 times
Are you checking the box on the parameter screen for the specific parameter you want the gauge to display?
- Has thanked: 427 times
- Been thanked: 123 times
As Robertwa says. Select the parameter/spot value you want to display first.
have selected and it has worked . thank you very muchJacobsmess wrote: ↑Tue Jan 21, 2025 9:00 pm As Robertwa says. Select the parameter/spot value you want to display first.
