Tesla Model 3 Charger
arturk
Has thanked: 7 times
Re: Tesla Model 3 Charger
Post by arturk »
Thank you for the update Damien and appreciate all the hard work!
Has thanked: 12 times
Been thanked: 356 times
So I had an oppertunity at the last ev conversion course to do some logging on a 2019 UK right hand drive model 3. Some charging logs up on the repo.
https://github.com/damienmaguire/Tesla-Model-3-Charger
Observed a peak of 10.5kw and a dcdc max output of 250A at 14V. Hope to get the PCS wired into the E46 over the next few days and start to try and wake it up for real.
arturk
Post by arturk »
Great news Damien!
Thanks for update.
Some good work today. Pcs is mounted and secure as is the high voltage junction box.
Need some help locating two components. The 12v high current plug and a european AC connector plug. As my pcs was US I only have the single phase connector plug. The ones pictured do not belong to me so I cant butcher them:)
muehlpower
Has thanked: 14 times
Been thanked: 144 times
Post by muehlpower »
Hello Damien,
I had the same problem. My solution is 3D printing. The contacts for 400V are Uni F630 from MTA, part number 1107940. For 12V Kostal PLK 14.5, part number 23124734300. The connector for the data is from TE connectivity, part number 1318774-1 for white or 1318774-2 for black.
The European PCS looks a little different. The board at the inlet is lower, the lettering is different, and there are two more fuses.
Thank you very much:)
Kevin Sharpe
Been thanked: 8 times
Post by Kevin Sharpe »
muehlpower wrote: Fri Mar 13, 2020 2:54 pm I had the same problem. My solution is 3D printing.
Great! Will you release the design as open source?
muehlpower
Kevin Sharpe wrote: Fri Mar 13, 2020 5:26 pm
Sure, but I don't know how open surce works and how I can share files.
Open source info : https://en.wikipedia.org/wiki/Open_source
Easiest way to share is on Github : https://github.com/
muehlpower
I'm not sure if it worked, but maybe the files are on:
https://github.com/muehlpower/EV-FFB
Perfect! Just placed an order. Thanks for sharing:)
pm_dawn
Post by pm_dawn »
Hi !
Damien, have you analysed the model 3 charger at the extent that you can verify that hardware design would support bidirectional charging?
regarding:
https://electrek.co/2020/05/19/tesla-bi ... -features/
Best Regards
/Per
jnsaff
Post by jnsaff »
pm_dawn wrote: Wed May 20, 2020 6:19 am Damien, have you analysed the model 3 charger at the extent that you can verify that hardware design would support bidirectional charging?
regarding:
Thank you for this bit of information, this is directly relevant to my day-job and may lead to funding research on this. Now needs to find a M3 PCS.
What I can tell you is this. When I had the PCS on the bench obviously I had no idea what CAN messages were needed to fire off the various functions and of course no one was sharing. So I used the fuzzing feature in savvycan to basically blast every possible message combination until something happened. A lot of seemingly weird stuff happened on the way to finding the messages INCLUDING AC APPEARING on the inlet pins , HVDC seemingly being generated from the 12v battery terminals and lots of other stuff I can't recall.
pm_dawn
Post by pm_dawn »
Jack Bauer wrote: Wed May 20, 2020 8:52 am What I can tell you is this. When I had the PCS on the bench obviously I had no idea what CAN messages were needed to fire off the various functions and of course no one was sharing. So I used the fuzzing feature in savvycan to basically blast every possible message combination until something happened. A lot of seemingly weird stuff happened on the way to finding the messages INCLUDING AC APPEARING on the inlet pins , HVDC seemingly being generated from the 12v battery terminals and lots of other stuff I can't recall.
That sounds really interesting !
Regards
/Per
clanger9
Post by clanger9 »
8-) Very, VERY interesting...
JaniK
Has thanked: 58 times
Been thanked: 14 times
Post by JaniK »
Jack Bauer wrote: Wed May 20, 2020 8:52 am ... A lot of seemingly weird stuff happened on the way to finding the messages INCLUDING AC APPEARING on the inlet pins , HVDC seemingly being generated from the 12v battery terminals and lots of other stuff I can't recall.
Soo, even connecting another car with jumper cables to 12vdc of M3 to charge the hv battery is plausible.. .. What wonders Elon has packed in the PCS that are not in use in their cars for now, will surprise us all.
jnsaff
Post by jnsaff »
clanger9
Post by clanger9 »
Great video, thanks Jaanus! Diodes on the vehicle side mean it's clearly unidirectional. Though this wouldn't tally with Damien's observation of AC appearing on the input pins. More research needed.
Interesting that they use the 12V battery to provide pre-charge Neat idea - saves having a big, ugly power resistor on the HVDC side... 8-)
I did wonder when we would get the first clickbait video on this topic. Didn't take long as usual.
clanger9
Post by clanger9 »
Is it correct though? If those are diodes, then it's not gonna generate AC...
Kevin Sharpe
clanger9 wrote: Thu May 21, 2020 11:54 am Is it correct though? If those are diodes, then it's not gonna generate AC...
The Ingineerix PCS is from a 2018 US car. iirc Damien has two PCS, one from a 2018 US car and one from a 2019 EU car. I have two from 2019 EU cars and we have lots in The Netherlands from various EU cars including a 2020 model.
Like everything else that Tesla make, the hardware *will* have changed over time. At some point Damien will work on the PCS again and we will know for sure what is supported by the hardware that he has 8-)
clanger9
Post by clanger9 »
Got it. Switching the diodes to FETs could happen at some point, so I look forward to Damien's analysis of the 2019 unit...
Kevin Sharpe
Oh well guess I imagined it all then.
