Hi everyone, hooking up a Leaf Gen3 PDM at the moment (running stack on the bench before picking a project car), but stuck on the Live/Neutral polarity of the AC charger input.
I don't have the original socket and cable, so trying to work it out..
I can see the cable has 2 orange wires for the AC, plus a PE cable.
At the PDM end, one AC line has black tape. Does anyone know if this is Live or Neutral?
Failing that, does anyone have a socket loom around (J1772 or Type 2), and can do a continuity check from one end to the other to see which is which?
Would really appreciate any help.
Thank you!
Leaf AC charger socket polarity
Re: Leaf AC charger socket polarity
Just wanted to feed back that the black marked cable is the Live.
- Been thanked: 1918 times
That's cool but from my study of the topology doesn't matter. Both cables run through a number of common mode chokes and finally a rectifier.
Missed your post earlier, otherwise could have spared you the research
