information where to purchase inverter (plug and PLay) simple for Nissan mote e (EM57)
imrannajeeb
Post by imrannajeeb »
hello all. I am new to this forum. i have nissan note e motor (E57 call IPMSM motor). it is salvage part of nissan note e. i think similar motor is used by Nissan leaf. i have also battery pack of nissan note e rated 2kw at 320v. i want to make series hybrid of my own using old suzuki liana car, em57 motor will be attached with manual gear assemble of liana and a small 3 cylinder engine rated at 40hp will run the nissan note e second genertaor rated 15kw. which will supply to battery of 320v.
i need an inverter which i install to nissan leaf motor. which run motor. just paddle sesnor for speed, regen braking and cos sign sensor for position.
can any one guide me where to buy inverter plug and play to start using nissan note e motor (e57).
Has thanked: 246 times
Been thanked: 469 times
Re: information where to purchase inverter (plug and PLay) simple for Nissan mote e (EM57)
There is no such thing.
Nothing here is truly plug and play.
There is not much information about the e note systems.
