Thanks for the heads up- might have to look into this and try to find one...
Edit: Found and ordered one!
Yaris Gen4 iBooster Gen2
Re: Yaris Gen4 iBooster Gen2
Unfortunately I had no luck even with the module wired in- still the same behavior- if I gently put pressure on the pedal the pedal sinks in to breaking point, if I stomp the pedal it gets hard for a splitt second, then goes soft down to the breaking point...
- Has thanked: 384 times
- Been thanked: 109 times
Hi, how did you find the right MC? Unfortunately my OEM MC has an 89mm bolt spacing whereas the one uses in the ibooster I have is 100mm. I could fabricate am adapter plate and extend the pushrod but something using the right bolt spacing, bore, hydraulic ratio and brake line connections would be a lot nicer.
Honestly, it was trial and error by ordering cheap used ones off eBay and seeing which ones fit... I have a box full of old an not-suitable master cylinders I'm trying to sell back on eBayJacobsmess wrote: ↑Thu May 15, 2025 7:43 am Hi, how did you find the right MC? Unfortunately my OEM MC has an 89mm bolt spacing whereas the one uses in the ibooster I have is 100mm. I could fabricate am adapter plate and extend the pushrod but something using the right bolt spacing, bore, hydraulic ratio and brake line connections would be a lot nicer.
I do wish Bosch had a catalogue with bore, port details and such but I can't find anything.
Chris
