Can you please plot this for me. There might be some tweaking you can do to your Zombie code to get a few more amps out.PetersonOctavius wrote: ↑Fri May 16, 2025 3:30 pm ully charged, isa shunt max Amp report is around 120-129A, throttle all the way down
GS450H gearbox with Camry inverter G9200-33171 [SOLVED]
- Has thanked: 204 times
- Been thanked: 558 times
Re: GS450H gearbox with Camry inverter G9200-33171
- Has thanked: 55 times
- Been thanked: 18 times
No need, I want to see the sag reported. Please plot left UDC and invUDC and right IDC
after 1 plot, the vcu will not start another plot
Was this flat out? Can you do IDC right and Potnom left?
Just want to see how much "throttle" is left
throttle wasnt fully pressed (user error, to focus on the logging and the end off the road ahead)
freshly downloaded
- vcu222A-16may.json
- (2.13 KiB) Downloaded 30 times
So you can change the values here in GS450h.cpp
I changed them to this to get more power before, I would say change it to 12500 and test if you get more power. If not there may be another limit like the Torque requested which we can also look at.
758 htm_data[81]=(10000)&0xFF; // discharge ability of battery
759 htm_data[82]=((10000)>>8);
New code will be then:
758 htm_data[81]=(12500)&0xFF; // discharge ability of battery
759 htm_data[82]=((12500)>>8);
Yes, the line numbers are for reference. I do not know if you added new lines.
changed the code to 12500, both lines.
went for a test drive, 124Amps at 340 volts
- Gregski
- Has thanked: 498 times
- Been thanked: 941 times
possibly have you logged your torque yet? when I did that on my VW Rabbit with the 3rd Gen Prius Inverter you can clearly see it pegs out at 3500 and wont go above that settingPetersonOctavius wrote: ↑Fri May 16, 2025 3:30 pm My pack is made of samsung sdi cells, 67Ah, 3C peak
96 cells
That would be 67 x 3 = 201A
Fully charged, isa shunt max Amp report is around 120-129A, throttle all the way down
It feels more like a torque request limit
Nope thats a fixed zombie setting request. Made no difference raising it on your setup.
Potnom direct translates to it.
quick run i did a while ago, potnom vs speed
never went above 6k rpm
negative rpm MG2 is forward on my setup
after quite some days of driving around, same oil pump problem came back.
driving...after while the pump turns of. i've been running it with a separate PWM generator, 1kHz, 16%duty
i started to think its the oil pump controller.
i ve been building drones for almost 10 years now, so i have some ESC (electronic speed controller aka inverter in the ev world) laying around.
i soldered one on the oil pump, it spun really slow but i managed to move the car. drones esc's are sensorless, just plug it in, give it pwm, it spins away.
so can i say its the pump controller?
- Gregski
i would go super basic and check and clean all them oil pump plugs and connectors and triple check its grounds
the little black side connector likes to break off and or bend its pins
i ordered this pump
its has a bigger and a smaller hole.
when i connected positive to positive, (as marked next to the pins) its sucks at the bigger hole, and pushes at the smaller hole.
with reverse polarity, it does the opposite which matches the gs450h pump, sucks from the smaller hole and pushes through the bigger hole.
im pretty sure it will make enough pressure to drive the car, for now i need an adapter so i can mount the pump to the gearbox.
i opened, it seems to be a brushed dc motor, runs smooth.
on the bottom side, there s a + mark
when connected to 12.7volts, it pulled around 3-4 Amps.its has a bigger and a smaller hole.
