Coupler Guidance
maiks
Has thanked: 7 times
Coupler Guidance
Post by maiks »
Hello,
I've designed a coupler that directly connects the Nissan Leaf EM57 motor to my gearbox. However, I'm facing a challenge: the coupler pushes too far into the gearbox, which ends up damaging (or "eating into") the aluminum section and causes the motor side to decouple.
I've attached images showing the affected areas.
After doing some research online, I found mixed opinions — some people recommend adding a stopper at the gearbox, while others don’t seem to use one at all, which has left me a bit confused.
I've ordered an upgraded coupler from BratIndustries (https://bratindustries.net/product/niss ... r-coupler/) and expect it to arrive soon.
zippy500
Has thanked: 83 times
Been thanked: 7 times
Re: Coupler Guidance
Post by zippy500 »
I followed what Damien did in one off his videos, just simply put some tack welds on the splines as a stop, although I'm yet to test it out
maiks
Post by maiks »
zippy500 wrote: Fri Jul 04, 2025 12:46 pm I followed what Damien did in one off his videos, just simply put some tack welds on the splines as a stop, although I'm yet to test it out
A friend tried it, but it makes noise whenever the coupler comes into contact with the welds, especially when driving at low speeds (around 30 km/h)
Has thanked: 222 times
Been thanked: 413 times
Loctite 660
Alibro
Has thanked: 417 times
Been thanked: 277 times
Post by Alibro »
When making my coupler I used two clutch plate centres with one inside the steel tube and one on the end. The one inside was rotated against the splines and welded through a hole on the side of the tube. This way there is no slop and no clunk when going from forward to reverse or using regen.
It may not be as neat as the Brat Industries coupler but has worked trouble free for the last 5000 miles for me.
I can't remember how I prevented the coupler from moving up and down the splines but so far it hasn't been an issue.
maiks
Post by maiks »
Bratitude wrote: Fri Jul 04, 2025 2:54 pmLoctite 660
How am l supposed to apply it , l request for guidance on this
zippy500
Post by zippy500 »
Must be good stuff, have seen the price of it.
Slimjimmy
Post by Slimjimmy »
Drill a hole for a set screw? Or press a bearing on the spline and use a spring to keep constant tension on the coupler which i imagine is free floating between both splined shafts
